Old 07-01-2012, 02:42 PM   #1 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Possible 6% mpg gain from adding a cone filter...Ford Focus...
Looks like maybe a 2 mpg (6%) gain from just adding a cone filter. I've had this filter laying around for a few years from another car....didn't think it would help since I already had the restrictive cold air intake nozzle removed from the pipe going to the front...and also the resonator box was removed allowing air from under the hood into the filter box.
IAT is probably close to the same as before...around 10F higher at 70F...3-4F higher at 90F vs ambient....so it's not likely a warm air issue.
Took 1/2 tank or so for the ECU to adjust.
Filter is laying on a piece of foam....OD of intake pipe and the filter pipe are the same...thus the tape and clamp. Just clears the hood.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 07-01-2012, 02:50 PM   #2 (permalink)
I am glad you put "possible" in the title.
aerohead (07-03-2012)
Old 07-01-2012, 02:53 PM   #3 (permalink)
My mistake. I meant GUARANTEED.
Old 07-01-2012, 04:05 PM   #4 (permalink)
Whitey - '10 Ford Ranger XL
Pickups
90 day: 33.74 mpg (US)
Hershey - '13 Nissan Altima SL
90 day: 28.68 mpg (US)
Midas - '10 Toyota Prius two
I once owned a Pontiac Vibe GT, aka Toyota Matrix (rebadged!). When I was younger I installed a K&N cold air intake full air system. I did see a noticeable jump in FE along with POWER, which younger me was all about. A few months later at an autozone I was bored and looked in the K&N book hanging off a chain and they were claiming a 15hp boost. I never tested the claim with anything more sophisticated than the seam of my pants. I do know smaller cars are choked by the EPA, my buddy got a intake system for his Ranger's 3L V6 and didn't see much difference.
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
Old 07-01-2012, 04:19 PM   #5 (permalink)
HydroJim's Avatar
Aerofocus (retired) - '00 Ford Focus ZX3
90 day: 44.66 mpg (US)
The Red Baron (sold) - '93 Geo Metro
90 day: 44.1 mpg (US)
Please do more testing because if this is true, I'll have to install one of these on my focus.
Old 07-01-2012, 05:47 PM   #6 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Noticed a similar increase on my intrepid when made they switch 6 years ago. I assumed the engine had slightly less vaccum under acceleration, maybe adding a little torque.
Old 07-01-2012, 06:35 PM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
What caused the improvement? Removing the cold air inlet? Removing the resonator? Changing from a probably dirty filter to a likely clean filter? A combination of all 3 actions? What?
So.... in other words, you don't know whether IAT has changed.
The Following User Says Thank You to t vago For This Useful Post:
Old 07-01-2012, 06:35 PM   #8 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
wrong
this is a CROCK O POOH
the EPA IATn BITOG AutoSpeed have all performed A B testing with various
"alleged performance" air filters including K & N
none of them (the tested filters) increase flow or fuel economy in any way at all at cruise
above a stock air filter
and the testing also shows that the K & N air filters do not actually "filter" the incoming air as well as stock OEM air filters
as you know the MAF sensor only samples a small percentage of the entire air flow and if the flow at the sample area is disturbed or re routed by tampering with the air box assembly then ....
your POS cone air filter very likely is not directing air flow to the MAF sensor correctly (as designed) and because of that the MAF is under reporting
this results in changes in the way the ECM assigns values to many thing
including spark timing and injector pulse width
you can test my theory by providing long term fuel trim with calculated load and MAF flow values and ign timing values at 55 mph on the same stretch of highway with your new POS filter and the original OEM filter
any generic OBD2 scan tool that can show real time live data can perform this task.
until then
this should be relegated to the UNICORN thread as it is bogus .
imho
The Following 4 Users Say Thank You to mwebb For This Useful Post:
aerohead (07-03-2012), Dawie (07-08-2012), Frank Lee (07-01-2012), TEiN (07-04-2012)
Old 07-01-2012, 07:37 PM   #9 (permalink)
The K&N filter may do one thing. It may increase max hp. It will do nothing mileage wise for any vehicle with a throttle, since any increase in flow will simply mean that you will close the throttle a little to compensate.
This really ain't rocket surgery.
I think that a low restriction air filter might make a bit of a difference on a diesel as it will lower pumping losses.
The Following 2 Users Say Thank You to pete c For This Useful Post:
aerohead (07-03-2012), mcrews (07-02-2012)
Old 07-01-2012, 07:58 PM   #10 (permalink)
We have been down this road 1000 times already. Unicorn.
