Old 02-01-2010, 03:16 PM   #41 (permalink)
Great info. I just wonder if they had not choked off the lean burn development with emissions restrictions (not against regulation but it should be weighed overall for effects), and allowed the developemnt of the newer ultra high pressure injection, if the combination of modern improvements could not have achieved HCCI by now.
Note:
By weighed overall they should have considered the ultra low C02 emissions against the slightly over reg NOX emissions.
regards
Mech
Old 02-01-2010, 09:39 PM   #42 (permalink)
The longer I work with this stuff, the less judgmental I have become. Often, when I run into something seemingly stupid in the regs I ultimately end up tracing it back to a compromise demanded by the automakers themselves.
The problem with NOx is that the curve is pretty steep. Something only has to be a little out of whack for NOx to soar. And, a lot of times those cases are coupled with a lot more soot, the sorts of carbon that cats don't readily clean. There are some good ways of dealing with both these issues, but there is still a problem with cost effective (and reliable) monitoring systems.
That's why we have active projects in both those areas. The thinking here is that there is no single magic bullet, so we should be facilitating multiple areas of 'incremental improvement' in emissions/fuel efficiency. Though, frankly, I'd just like cheap and effective NOx sensing so that I could get rid of the noisy canary in my office (sorry, inside joke, I'm the lab gas nazi here, and get tormented for it).
-jjf
Old 02-02-2010, 02:19 PM   #43 (permalink)
Mater - '98 Dodge 3500 Dually
Wilber - '99 Toyota Corolla LX
Minyatta - '93 Mazda Miata MX-5
Note:
regards
Mech
Agreed! Along the line of what was done to improve the diesel since 2003, ultra high pressure injection.
Old 02-02-2010, 03:39 PM   #44 (permalink)
The 1992-5 Civic VX was rated at 4.30 tons of total greenhouse gas emissions. That is less than either the 2010 Insight or the 2010 Civic Hybrid.
The 4.30 tons was for the Federal version. It's about 33% of the figure for a Ford Expedition of the same year.
I am no expert in emissions regulations, but it certainly seems like it would be more conducive to development of truly efficient vehicles if the specific categories of allowed emissions were weighed against the sum totals of all emissions.
I think European regulations are more focused on CO2 which is more directly related to mileage, but I would not want to state that as factual, since I don't feel qualified to make that kind of judgement.
It was surprising to see the now 16 year old lean burn Civic produce less than either of Honda's currently best examples.
regards
Mech
Old 02-03-2010, 08:16 AM   #45 (permalink)
Totally.
I don't understand why they weren't put in even more Honda's. & whey did Honda keep the VTEC-E such a secret? I've owned many Honda's over the years, I didn't learn about the lean burn until a few months ago. What an amazing design, especially for a production car. Can't this technology be further developed?
Dave
Old 02-04-2010, 01:38 PM   #46 (permalink)
Totally.
Dave
I don't want to come off as a naysayer, or defender of regulations, but a lot of these issues are more complicated than they may seem at first glance. I also am not an expert in this particular area, so take the following with a grain of salt.
One big problem with this lean burn technology is that it only works at light loads. When you place demand on the engine, it is going to work pretty much like any other engine. When you are running in those ranges, you are going to pollute like any other engine. So, you probably want emissions systems.
The problem is that when you are burning lean, you have a cool, O2 rich exhaust which not only renders a cat ineffective, it rapidly destroys it. So you end up with an engine that puts out higher NOx at low loads, and which is waay dirtier at high loads.
Now, the natural question is, how could that be? Look at the comparison in total gasses! But that assumes that we are comparing apples to apples. Look at the vehicle weights and performance stats of the vehicles being compared.
Car makers gave consumers what they wanted. Bigger, faster cars, filled with Barca Lounge Chairs with built in cup holders.
As engines get bigger and bigger, low load operation moves farther and farther out of the engine's "efficiency island". Think about it, a big SUV needs a big engine to start hauling 8 people and a boat, but only 15-20 HP to maintain speed with 1-2 people on the freeway. So that big engine is throttled waaaay back. That is effectively vacuum, which drags down the VE of the engine. You can only expand compressed gas to the ambient pressure, so this is a very inefficient way to convert energy.
As Honda started making heavier cars, the lean burn engines had to get bigger, and they got dirtier, because they were operating less efficiently more of the time. To get the pollution down to permitted levels, they first looked at running leaner, but at stoichiometric ratio. That may sound like a contradiction, but 'leaner' doesn't have to O2, it can be exhaust gas. I'd have to go looking at some of the papers, but the general problem with this was that it only worked if you eliminated turbulence (I think it had something to do with thermal boundary layers). That is, you had to get rid of the vortex generation.
But the vortex generation is what was permitting the lean burn to be used efficiently! So it was a catch 22...
Really, the problem is three fold. First, there is a matter of consumer taste. If consumers would buy lighter, lower frills vehicles, we could make them more fuel efficient than the same vehicles where two decades ago. The second problem is political. Look at the comment about diesel above. The big barrier to those technologies in the US was not emissions regulation, but the money and politics behind sulfur heavy fuels. In many ways, regulation is at the wrong end of the problem, but money and politics make any other point of regulation very very hard. The last problem is control. There are some very promising paths to better efficiency, for example, we were just talking about HCCI here. But there needs to be some technological innovations to reliably deploy these techniques at the consumer level.
Hopefully, I am at least involved in #3 in a small way. One and two are beyond my control. I don't even check the box to donate a couple bucks to campaigns on my tax return, so it is safe to say that my political clout is zero...
-jjf
The Following User Says Thank You to jfitzpat For This Useful Post:
Dave's Civic Duty (02-05-2010)
Old 02-04-2010, 02:06 PM   #47 (permalink)
...beats walking...
-jjf
...the only political box I want to check is:
[ X ] None of the above.
Old 02-05-2010, 08:36 AM   #48 (permalink)
Thanks jjf,
Thanks for the Ivy League school explanation. The only thing that was missing was the drawings on the board.. I see! I glad I'm driving my little mechanical wonder!
My VX is getting better mileage then the new 4dr.Civic Insight that is being tested in my latest Popular Science, that I just got in the mail yesterday. My last tank was 47MPG their best was 45MPG. Cost new is over 23,000, mine was free. Nothing political about that & I personally love that consumer taste!
Please keep working on #3, for the air that we breathe!
Thanks for opening my eyes,
Dave
welded body dropped rpms..and that... bgd73 Success Stories 27 06-24-2009 09:31 PM
Lower idle RPMs save gas? Xringer EcoModding Central 5 06-14-2008 10:19 PM
Accelerating and shift points bhazard Hypermiling / EcoDriver's Ed 26 04-25-2008 04:52 PM
