Old 01-22-2015, 03:12 PM   #1 (permalink)
90 day: 29.78 mpg (US)
Prius Roof Antenna Delete
Is there a way to delete the silly looking roof antenna on the gen III Prius? Not only is it causing a slight amount of drag, but it could get damaged in a car wash and it looks unsightly.
The shark fin antennas look to be shaped incorrectly also. They have abrupt trailing edges and would perhaps be more aerodynamic if installed the other way around.
Ideally I would just connect a flexible wire antenna and hide it under the dash.
I wonder why all manufacturers don't opt for integrating the antenna into the rear window?
Old 01-23-2015, 04:42 PM   #2 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
YKYAEI!
heh, what about just a hammer and chisel?
And take off that massive rear wiper blade too...
Old 01-23-2015, 04:58 PM   #3 (permalink)
I can't imagine this will have any noticeable affect on your FE.
Cd (02-07-2015), Xist (01-24-2015)
Old 01-23-2015, 08:02 PM   #4 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I ended up just putting a shark fin antenna on; I figure it's better than that thing sticking 7" up into the airstream (and it probably is). Is it a huge difference? No. But, every little bit helps, and little bits add up. I also removed the rear wiper and motor with a nylon plug from Lowe's and some silicon.
You can probably relocate the antenna to inside the car, but you'll have to remove the headliner to get at the base and I have no idea what it looks like under there, not having gone that way myself. I would imagine you could find a shop that would fill the resulting hole and paint; on my Ram, the shop that owned it previously had done this with the OEM fender-mounted antenna and I couldn't tell there had ever been anything there.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following 2 Users Say Thank You to Vman455 For This Useful Post:
Cd (02-07-2015), redpoint5 (01-23-2015)
Old 01-23-2015, 10:20 PM   #5 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
In my car, the rear light housing gives access to a nut that holds the antenna on.
Old 01-24-2015, 03:13 PM   #6 (permalink)
Does the shark fin have a greater frontal area? I imagine that it would create a minuscule improvement, slightly greater if positioned "backwards," while "Dude! Your antenna is backwards!" would definitely be noticeable.
Old 01-24-2015, 03:43 PM   #7 (permalink)
Those shark fin antennas look to me like rooftop cargo boxes in that they are positioned backwards from the most efficient aero shape. If there must be a blunt surface, it should be the leading edge, not the trailing.
The Following 2 Users Say Thank You to redpoint5 For This Useful Post:
Cd (01-25-2015), dirtydave (01-24-2015)
Old 01-25-2015, 01:34 PM   #8 (permalink)
Can we make a shark-fin windtunnel? For... testing?
Old 01-25-2015, 02:03 PM   #9 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I think the public has had it drilled into their minds that a pointed front is always best. When I look at jets and rockets, I can see how that people could think this, since the front is pointed and the back end is an open flat end.
Old 01-25-2015, 04:36 PM   #10 (permalink)
I should clarify, the interior rear light housing.
