Old 11-23-2022, 09:29 PM   #1 (permalink)
90 day: 29.78 mpg (US)
Recommend Spot Welder
I have a portable spot welder I bought to connect nickel battery tabs. It was garbage and would only weld a couple tabs before being too low energy to make an OK connection. I don't even consider them that ok. Then it died.
All the highest rated spot welders on Amazon are portable. Then there's bench welders that all have lower ratings and are about 4x the price.
No reviews say they can weld 2mm nickel reliably.
Anyone know of any product capable of making good welds on battery tabs? Seems like the market is flooded with junk that doesn't work and there's nothing at any price for consumers.
Old 11-23-2022, 09:44 PM   #2 (permalink)
Link is a dead end, but I've got one of these:
https://external-content.duckduckgo....d2e&ipo=images
This comes with a spotwelding head
Old 11-23-2022, 11:10 PM   #3 (permalink)
I got the harbor freight 240v one.
Turns out they are good for making sten guns.
Old 11-24-2022, 12:36 AM   #4 (permalink)
I only see this, which is suitable for joining sheet metal or something, but wouldn't be capable of joining battery tabs
https://www.harborfreight.com/240v-s...der-61206.html
Old 11-24-2022, 01:09 AM   #5 (permalink)
What -- exactly -- are you trying to accomplish?
Old 11-24-2022, 01:19 AM   #6 (permalink)
"connect nickel battery tabs"
freebeard (11-24-2022)
Old 11-24-2022, 12:42 PM   #7 (permalink)
So the pincer-style spot welder is right out. Try renting the style in #2.
Have you considered a laser?
Old 11-24-2022, 12:44 PM   #8 (permalink)
I did see something on Alibaba marketed as an untrasonic welder for $8,000.
When I say I'm willing to pay any price, I mean any reasonable price for achieving the correct temperature for the correct duration to sufficiently fuse nickel with steel.
*Oops, just realized I've been incorrectly saying zinc instead of nickel. Corrected.
Old 11-24-2022, 01:14 PM   #9 (permalink)
https://www.periodic-table.org › nickel-melting-point
Nickel - Melting Point - Periodic Table
17 Nov 2020 Melting point of Nickel is 1455°C. Note that, these points are associated with the standard atmospheric pressure.
en.wikipedia.org/wiki/Laser_beam_welding
Old 11-24-2022, 05:04 PM   #10 (permalink)
May need to build your own I bet there's a few on youtube.
redpoint5 (11-24-2022)
