Old 10-19-2011, 02:48 PM   #41 (permalink)
The DX - '91 Honda CRX DX
Last 3: 33.49 mpg (US)
The Race Car - '91 Honda CRX Si
90 day: 28.35 mpg (US)
The DX v2.0 - '91 Honda CRX DX
Last 3: 35.11 mpg (US)
DX v3 - '91 Honda CRX DX
Originally Posted by ebacherville View Post
why they even use drums at all is a total mystery to me , discs are far more efficient and far easier to work on .. with the invention of discs the drums should have been dropped completely.. I don't get it , anything over 30 years old should be discs all the way around.
Cost reduction.
Old 10-27-2014, 11:28 PM   #42 (permalink)
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
out of round drum
Originally Posted by Gasoline Fumes View Post
I pulled out the auto adjusters from my Civic's rear brakes. The shoes were definitely dragging before I did this.
Thanks to you I've figured out how to remove the self adjusters. However, the main issue turned out to be an out of round drum. In retrospect, this was evident when spinning the wheel, as the wheel kept meeting resistance at the same place on each spin. I'm having the drum turned tomorrow, will see if it helps, and then will check the other one. I read that using the parking brake when the shoes are hot can cause the drum to warp, so I will use 1st gear from now on and refrain from using the parking brake. I can tell which brakes are dragging, because they melt the coroplast.
Old 10-27-2014, 11:40 PM   #43 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Originally Posted by EF TuneRR View Post
Cost reduction.
Yep. And it's nice how it's going to cost me around 700$ to do a convert to disks on my '91 Fox ............ -.-
Old 10-28-2014, 03:14 AM   #44 (permalink)
You'd do that why?
Old 10-28-2014, 07:06 AM   #45 (permalink)
Furry Furfag
You'd do that why?
What? Convert to disks? My brakes start smoking and I lose almost all braking power after one lap around the neighborhood. The '91 fox is going to be my drag car when I'm done with it. 331 stroker kit, cobra intake, AFR 185cc heads etc etc.
Old 10-28-2014, 09:27 AM   #46 (permalink)
You'd do that why?
Why don't you just pour gasoline in a fire, you crazy?!
Old 10-28-2014, 10:21 PM   #47 (permalink)
Liberty Lover
j12piprius's Avatar
removing the back wheel drag
The back left wheel spun only 5 to 11 times at first, so I loosened the e-brake from 4 to 6 clicks, and the wheel spun 21 to 26 times, however kept catching at one place. I took the drum off, cleaned everything, removed the auto adjuster, and loosened the star 20 turns until the wheel spun smoothly.
I took the drum in, the mechanic only did one turn and said it was fine, no change, but it did seem a bit better. I tightened the star but the drag came back, so I let it back out and put the wheel back on. Now the wheel spun 31 times. I jacked up the right wheel and it spun 31 times, took it apart, removed the auto adjuster, put the wheel back on and it was catching at one place. I took it apart, turned the star 2 turns, put the wheel back on and it spun 32 times.
I think the wheels are much better now, especially the one on the left, and I learned quite a bit by doing this.
CdA list Daox Aerodynamics 206 10-25-2023 06:32 PM
Does reducing ground clearance REALLY reduce drag? cbergeron Aerodynamics 106 06-25-2015 04:47 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
aero-mods,installment#9(internal drag) aerohead Aerodynamics 39 07-11-2008 05:45 PM
DIY Needed - adjusting parking brake pull Yaristock DIY / How-to 22 04-17-2008 09:51 AM
