Go Back   EcoModder Forum > AltModding > Saving@Home
Old 07-05-2014, 12:54 AM   #11 (permalink)
I have been wondering about insulating an oven. Could you minimize the heat it releases into the kitchen and save energy?
It was not unusual in older ovens to have a built-in glass-wool blanket. I remember dismantling a few old ovens to take some glass-wool to use for sound-deadening in exhaust pipes for motorcycles.
Old 07-05-2014, 01:09 AM   #12 (permalink)
Drive less save more
ecomodded's Avatar
90 day: 60.42 mpg (US)
I blocked my ovens vent hole a few years ago with no issues besides a more economical oven.
The vent is a 2" diameter vent pipe that leads from the oven roof to under the element drip dishes.
I press fit a piece of tin foil over the pipe hole. Do at your own discretion , I can say my oven has not been damaged. I estimate the vent hole causes about 30% more energy consumption , as the heat loss is continual.
Save gas
The Following 2 Users Say Thank You to ecomodded For This Useful Post:
Highbeam (04-26-2016), Xist (07-05-2014)
Old 07-05-2014, 04:47 AM   #13 (permalink)
90 day: 57.12 mpg (US)
Mmm. The ventilation may be necessary to prevent heat damage to what's underneath the oven or maybe some components inside.
We have a 15 year old combi oven on top of the old fridge. The fridge top was discoloured from the heat; I checked it when in use and indeed it got very hot.
I took it apart; the fan and all of the ventilation and air guides etc. were covered in a greasy mush. Now it's clean it heats better and the bottom stays much cooler.
Old 07-06-2014, 01:54 PM   #14 (permalink)
Back that fridge's heat exchanger up against a plenum that is open to the outside in the summer and the inside in the winter. That will improve the efficiency of the house/refrigerator subsystem.
Also this:
Old 07-06-2014, 09:34 PM   #15 (permalink)
A guy from Hawaii on the insight form posted an adjusted thermostat to use a chest freezer as a fridge. The idea is since its a top opening box the cold air doesnt fall out when you open the door. Since it was built as a freezer it has better insulation and guts, so using it to cool to just above freezing saves a lot of money.
