Old 04-08-2022, 07:17 PM   #31 (permalink)
Originally Posted by 19bonestock88 View Post
It seems that nobody is suggesting the fairly obvious choice here. What OP need to put in his S-10 is another GM 2.2, the Ecotec.
Brazilian S10 and Blazer had 8-valve 2.2 and 2.4 versions of the Opel-designed Family II engine, a direct predecessor to the Ecotec. The post-facelift "Samba" Blazer assembled in Indonesia had the 2.2 and 2.4 Ecotec engines sourced from Australia.
Old 04-30-2022, 10:32 PM   #32 (permalink)
Originally Posted by Gasguzzler View Post
Same problem with a turbo, turbo ing an engine is always less reliable and the cost of the parts and need for premium fuel would make the savings from potential mpg gains less significant.
"Always less reliable?" Isn't that a bit of an absolute? I only saw reliability issues when people slap a turbo to a car without building the car to handle it. i.e. no real plan: no remapping fuel curves (or going to aftermarket FI computer that can detect and properly handle boost), no wideband O2 sensor tied into FI system, no ensuring fuel system can deliver the fuel (as opposite to be on its last legs), and so on. And they they decide to do burnouts, go lean, throw rod or grenade transmission, and it is the turbo's fault, not them being idiots.
Just because you are going to turbo an engine does not mean it can only be used to do 10s quarter miles or faster. A lot of factory turbo cars are built with relatively small turbos so they are useful on the low end, as in passing someone or getting up to 45mph at a brisk acceleration. At highway speeds the turbo is not doing much unless you are climbing mountains, when it may also help the engine see sea level air pressure.
With that said, I know of at least one 2.3L car doing 500HP which did not have any issues besides normal maintenance for more than 10 years now. The fact the owner does not drive it as if he has to drop the clutch between traffic lights may be a factor. Still, I thought this thread was all about economy, so methanol injection, forged crank and rods, and dropping the CR to 8.5:1 really do not belong here.
If turbos did not help with fuel economy they would not be used in 18 wheelers.
When it comes to turbocharging a port-injection engine, it's also worth remind they may need a richer AFR to prevent knock, even when an intercooler is also used.
In the 80s the recipe to deal with boost was to add 30% more fuel. In more modern times, a wideband O2 attached to a FI system that is smarter than the average politician can do a lot. Add support for knock sensing (you could copy the old APC system if you want to be lazy, but nowadays you can do much better) and ensure your FI system can adjust ignition timing and boost on the fly, and you may have a good starting point.
FYI, I do not remember the last time I saw a factory turbo car without intercooler. I have seen people build their own forced induction, specially supercharged ones, without it but then again some think that intercooling and wideband O2 sensors are witchcraft, and the only approved fuel system is a carburator.
Originally Posted by Isaac Zachary View Post
A forced induction engine will usually need to have a lower compression ratio that will also lower its fuel efficiency, not to mention when you hit the throttle it will need to enrich. Or you need to buy premium, or all of the above.
Most cars using turbo for economy have compression ratio around 11:1 nowadays. They usually are set to handle under 10psi of boost, but more modern fuel systems can push the envelope.
It seems that nobody is suggesting the fairly obvious choice here. What OP need to put in his S-10 is another GM 2.2, the Ecotec. The first generation L61 is a simple engine to hook up and run and I can speak from experience that they’re pretty efficient. They also happen to love boost if the ~140hp/145lb/ft in stock trim is insufficient, and there are factory parts that can accomplish that from a junkyard, cheap. I’d wager that 30-35mpg wound be very doable with modest gearing and maybe some aero that were done at the same time as the swap
I too agree that would be the smartest thing to do: modern engine with modern FI system.
Old 05-01-2022, 04:33 PM   #33 (permalink)
ME personally, 4.8 LS would be a smart swap and then find the aussie version of the tune to incorporate the lean cruise or you could go with the 4 cyl ecotec or the v6 3.0 or 3.6 all depends on your funds and availbility and mechanical ability. then of course aero
Old 05-02-2022, 01:54 AM   #34 (permalink)
Diesels are a whole different deal, even though nowadays as direct injection became more common on gassers a turbocharged gasser with direct injection may eventually reach a better fuel-efficiency than a port-injection one with natural aspiration within the very same displacement bracket.
When those Fueltech aftermarket programmable ECUs became more popular within the drag-racing scene in Brazil, carburettors started to get out of favor among street racers too.
No wonder nowadays I see many engine platforms which still resort to the good old port-injection for the naturally-aspirated versions, yet they switch to direct injection for the turbocharged ones.
Old 05-18-2022, 11:16 AM   #35 (permalink)
Com Car - '06 Honda Civic EX sedan
Familycar - '10 Ford Edge SEL
Go for the low hanging fruit. Reduce any rotational mass. Electric fan, under drive pulley, lighter rims and if MT lighter flywheel. Just the fan & flywheel would make a big difference.
Old 05-18-2022, 10:53 PM   #36 (permalink)
Even just the fan would be a great improvement, plus it's a much lower-hanging fruit
