Old 03-27-2009, 12:33 PM   #1 (permalink)
Legend in my own mind
trikkonceptz's Avatar
Evil Pumpkin - '08 Scion xD RS 1.0 #1633
90 day: 35.45 mpg (US)
Silent Silver Killer - '10 Honda Insight EX
90 day: 51.5 mpg (US)
Shark Fin Antennas
I know many of you have seen them and they offer them for just about every vehicle as a replacement to OEM antennae. My question is not if they are better than some stock whip antennas but if they would do more good backwards instead of forward facing because of surface area that faces the wind. This link has the picture. Mind you some designs are thicker because they have to house an antenna base.
http://www.visualgarage.com/Ebay/Sha.../Fin_Cad_1.jpg
Thx NoCO2; "The biggest FE mod you can make is to adjust the nut behind the wheel"
I am a precisional instrument of speed and aeromatics
If your knees bent in the opposite direction......what would a chair look like???
Old 03-27-2009, 01:01 PM   #2 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
It is hard to tell from the picture if the rear of the antenna is square edged, or if it is rounded. It would certainly be better if rounded.
Winter daily driver, parked most days right now
Summer daily driver
Old 03-27-2009, 01:40 PM   #3 (permalink)
I dont think it had a sharp edge in the rear, I am getting it regardless, I just wondered if it would be better if mounted backwards ..
Old 03-27-2009, 02:17 PM   #4 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
mount it forward and add a mini-boattail to it
Old 03-27-2009, 02:18 PM   #5 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
trik, I get what you are driving at...
But it is not the teardrop tapering OUTLINE that is important, it is the overall cross section profile area that needs to taper to be better aerodynamically.
It is due to this reason that some early fast fighter aircraft fuselages had a strange 'dimple' at the point where wings met the fuselage The wings added a sudden additional area when cross section is considered. That prevented the aircrafts to overcome drag particularly flying close to Mach1 figure. the trick designers used there was to give a 'dimple' in the fuselage, that reduced sudden increase in the cross-section area. This helped push aircrafts to higher speeds. google and you can find some references in the US air force fighter aircraft history.
The sharkfin antenna does look fatter at the front tip than the end - if the end is tapered in its vertical wall cross section, it would be better. Jury is out on that here as the rear view is not clear.
Old 03-27-2009, 04:03 PM   #6 (permalink)
vtec-e's Avatar
De Yaris - '04 toyota yaris T2
90 day: 69.55 mpg (US)
Whoaaaa!!! There's a random nugget of knowlege! Thanks!
ollie
Old 03-27-2009, 05:17 PM   #7 (permalink)
WonderWagon - '94 Ford Escort LX
Last 3: 51.52 mpg (US)
DaBluOne - '99 Ford Escort SE
90 day: 48.97 mpg (US)
DaRedOne - '99 Ford Escort ZX2 Hot
Never heard of Shark Fin Antennas before, so I googled them.
Found this animated gif that may help visualization.
Extracted Frames:
ID:	3082   Click image for larger version
ID:	3083   Click image for larger version
ID:	3084   Click image for larger version
Old 03-27-2009, 05:19 PM   #8 (permalink)
Rest of Extracted Frames:
ID:	3087   Click image for larger version
ID:	3088   Click image for larger version
ID:	3089   Click image for larger version
Old 03-27-2009, 06:23 PM   #9 (permalink)
Weight Reduction
Drive Stick's Avatar
Celica GTS - '02 Toyota Celica GT-S
90 day: 36.32 mpg (US)
Send a message via AIM to Drive Stick
It's designed perfectly for the most part facing forwards. Backwards it would create wind noise, and more drag.
As it sits it's like a little kammback vehicle, it's perfect really.
Old 03-27-2009, 06:27 PM   #10 (permalink)
Weight Reduction
Oh, and by the way my brother put one on his new 08 Altima... the radio no longer works.
Everything is installed properly, it simply can't compete with a stock antenna it doesn't even pick up local stations (with in 15 miles) that's pretty sad.
