Old 04-09-2010, 03:29 PM   #11 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Try this for an idea:
http://ecomodder.com/forum/showthrea...-6-a-6069.html
Old 04-09-2010, 05:34 PM   #12 (permalink)
want
Originally Posted by Hermie View Post
According to a French study (Peugeot/Citroen), the large counter-rotating vortices I'm getting are really reducing rear lift while also slightly reducing drag.
Their tests show that vortex generators are MUCH more effective at reducing lift than drag, and the large counter-rotating vortices I'm seeing on my rear window means that the VG's are doing their job quite well:
"It appears that the largest drag and lift reduction is clearly associated to a strong increase of the size of the recirculation bubble over the rear slant."
Here's the paper:
SpringerLink Home - Main
This is exactly what I want- Reducing lift, with drag reduction as an added bonus.
By moving the separation point rearward,the base pressure is increased in the wake when it does occur,reducing both drag and lift as a consequence.
Circulation of any form is robbing your gas tank,as this kinetic energy cannot be converted to static pressure which leads to lower base pressure and higher form drag.
The VG is a palliative for inherently inefficient designs.
The Kamm-back offers no horizontal surface in the aft-body where lift can occur,as it moves all the 'lift' directly behind the vehicle,eliminating any vertical component.Also,the longer the tail,the smaller the wake,higher the pressure,and lower the drag.And no lift.
If you'd like to see a perfect low-drag,low-lift roofline,GOOGLE an image of the Ford Mk IV race car of the mid-1960s.It has a textbook Kamm body and track-proven stability.
Old 04-09-2010, 08:29 PM   #13 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
aerohead -
Is this it? :
(NSR slot car version)
CarloSW2
American Solar Energy Society
Old 04-09-2010, 10:18 PM   #14 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
Actually, kammbacks do create lift from the low-pressure zone above them created by the downward angle. The air fills up the gap generated as it moves through the air, causing the molecules to spread out more. If you take a look at the Honda Insight's wind-tunnel smoke testing, you'll see the gap widen between the surface and the smoke trail as you come to the rear edge, indacative of lowering pressure. Though if you added a kammback to, say, a 3 box sedan (fastback), you'd most likely see a reduction of rear lift, but it won't be eliminated.
The rear on that race car pictured would be more of a fastback, and I'm sure that ducktail spoiler adds quite a bit of drag with it's downforce.
In Reason we Trust
Old 04-10-2010, 02:05 PM   #15 (permalink)
No.9
Originally Posted by cfg83 View Post
aerohead -
Is this it? :
CarloSW2
Carlo,the number-9 car is it! I'm not sure what the upper one is maybe Alfa Romeo,Ferrari,perhaps a Chaparral.
With the #9 car,if you can imagine narrower tires and the body sides narrowing along with the roofline,that's Kamm's form.This car also chops the body at the 50% mark as Kamm advocated.It's one of only a hand full of cars to do it ( Ferrari F 40 and Bugatti EB 110 use it ).
PS the Ferrari F335 Berlinetta comes very close with it's rear spoiler.
Old 04-10-2010, 02:35 PM   #16 (permalink)
Kamm-back
AeroModder,I'm going to have to respectfully disagree with respect to your assessment of the Kamm-back.
It's true that the eruption of the roof and accelerated flow over the windshield causes lift,although that's something we've got to live with if we're going to have a greenhouse on vehicles.
With respect to the roofline,the smoke trails spreading apart is indicative of the streamline flow deformation caused by the passage of the car,rebounding to it's undisturbed orientation,with a deceleration in the flow and consequent pressure rise.
With the Insight,the curvature of the roofline,in my opinion,is too aggressive,and what you are witnessing is flow separation,as the streamline is unable to follow that contour.
I agree that there will be lift over the hatch on the Insight,as the pressure above the hatch is that of at the point of separation.With a 'proper' Kammback,separation is impossible( that's it's premise) over the hatch,and is moved to the 'back' of the car where vertical lift cannot occur.
If your 3-box car has good flow up to the attachment point of the Kamm-back,aside from the lift ocurring at the windshield,it is not possible for the Kamm-back to add lift,only reduce it or eliminate it,as the pressure is acting on a vertical wall.
The Ford Mk IV has fully attached flow all the way to the 'end' of the car,and since the rear is cantilevered,the base pressure will actually produce downforce due to the torque acting between top and bottom of car.
Please GOOGLE an image of the 1994 Bugatti EB 110.This is a $350,000,207-mph supercar with perfect Kamm-back.And feel free to compare it to the Aerodynamic Streamlining Template.
Old 04-10-2010, 08:23 PM   #17 (permalink)
AeroModder's Avatar
Team Ford
I see. So the "Kammbacks" used in mass-produced vehicles today fall short of the ideal angle. I was thinking more along the lines of what is out there than the idealized version. My mistake.
In Reason we Trust
Old 04-11-2010, 01:36 AM   #18 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Hello -
More Ford Mark IV pix :
Sports Car Silhouettes
Slot car pix are from here :
Espectacular Nsr Ford Mk.IV gt 40 Gulf | Noticias de scalextric de todoslot.es
CarloSW2
The Following User Says Thank You to cfg83 For This Useful Post:
aerohead (04-12-2010)
Old 04-12-2010, 09:17 AM   #19 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
Why does the Mk IV have the spoiler on the rear edge (it seems rather large on the sides)?
Old 04-12-2010, 09:48 AM   #20 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
Patrick -
Do you mean along the side curving up? Maybe for downforce?
CarloSW2
Tuft Testing - "Vortekz" vortex generators on 2003 Jetta Rear Window Deezler Aerodynamics 40 07-15-2017 01:56 AM
Belly pan or vortex generators? edbso Aerodynamics 125 02-22-2011 12:50 PM
Help choosing vortex generators Fit Aerodynamics 58 01-08-2011 04:08 AM
tuft testing, vortex generators, and God's own wind tunnel jim-frank Aerodynamics 10 06-27-2009 02:48 PM
vortex generators at rear bumper?? crexcrex Aerodynamics 14 08-22-2008 05:11 PM
