Old 11-17-2018, 10:41 PM   #11 (permalink)
Originally Posted by jamesqf View Post
Where would you find a 3-cylinder radial? I don't think I've ever seen a radial engine that wasn't for aircraft use,
Yeah. Anyway, see my permalink #9 above. The Revetec cam lobe engine may be a better idea.
Old 11-18-2018, 01:04 AM   #12 (permalink)
Turning the power 90 degrees is not as efficient as gearing in the same axis.
Flatheads have far less efficient combustion chambers than OHV.
Lubricating downward pointing cylinders might get funky. Yes, radials are lubricated but with a simple sump and pump?
Daschicken (11-18-2018)
Old 11-18-2018, 02:02 AM   #13 (permalink)
All true.
How abour the ReveTec idea?
Old 11-18-2018, 08:55 AM   #14 (permalink)
Can't get that either, right?
Old 11-18-2018, 09:13 AM   #15 (permalink)
Not Yet.
Old 11-18-2018, 01:53 PM   #16 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Angel And The Wolf View Post
I've read that a radial engine (Radial, not rotary) is lighter and more powerful than an inline engine of the same cylinder number and displacement.What are the objections to a horizontally mounted three cylinder radial engine in place of the inline four the Prius comes with?
I can't see it being lighter than an inline 3 cylinder - comparing apples to apples.
OK, the crankshaft is a lot shorter, but ...
Needs 3 (double) camshafts & 3 mechanisms to drive those
Cylinder walls are not shared with the next cylinder
Needs 3 separate water jackets & piping
Needs 3 separate intake & exhaust headers
Needs longer fuel lines, wiring harness
On top, 3 cylinders in a radial pattern will take up much more space than 3 IL.
Radials are notorious for leaking oil
The Following User Says Thank You to euromodder For This Useful Post:
Xist (11-20-2018)
