Old 09-24-2011, 06:50 PM   #1 (permalink)
Whitey - '10 Ford Ranger XL
Pickups
90 day: 33.74 mpg (US)
Hershey - '13 Nissan Altima SL
90 day: 28.68 mpg (US)
Midas - '10 Toyota Prius two
Trucks- cab/bed sealer
So I was walking around Lowe's after my wife's break from work today and inspiration hit me! I saw a Replacement Gasket Kit for stoves, fireplaces and furnaces. The package actually says "prevents air leaks, Improves efficiency" in bold letters. It contains a braided rope and gasket cement. The sizes I saw were 3/8" and 5/8". I went and measured my Ranger: top gap is 1", side gaps are 1 1/2" and the underside is 2".
Provided I can find the appropriate braided ropes, does anybody see a problem with this aero-mod?
Check out my facebook page, if you feel like watching my progress.
http://www.facebook.com/pages/MPGran...007268?sk=wall
Old 09-24-2011, 11:02 PM   #2 (permalink)
idk. try it see if it works. also purchase some goof off in case it doesnt...
edison invented the light bulb after 1000 tries.
Old 09-24-2011, 11:29 PM   #3 (permalink)
JasonG's Avatar
05 DMax - '05 Chevrolet 2500HD
90 day: 18.48 mpg (US)
Hmmm,
Haven't seen it with gasket cement before. You mean like Permatex / form-a-gasket ?
The old stuff with retort cement would harden and crack, then fall out from the vehicles vibration.
With a flexible cement, it might work but would be tough to get to look good.
You don't need the fire retardant rope. Try 2" backer rod with smaller ones then regular urethane caulk.
That's how gaps are filled in concrete walls and it lasts many years.
And urethane caulk is paintable.
I can't understand why my MPG's are so low..........
21,000lb, 41' Toy Haulers are rough on FE!
Old 09-25-2011, 04:10 PM   #4 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
Be careful. There is a lot of movement between the cab and the box in a pickup truck. I believe that other aero mods will have much larger benefit. But if you really want to seal that gap, I've seen a foam gasket about 2 inches square in the hardware store. It's designed for air conditioners or something. Bond it to either the cab or the box and let the other side slip.
The Following User Says Thank You to JRMichler For This Useful Post:
d3vi1d06 (09-26-2011)
Old 09-25-2011, 08:41 PM   #5 (permalink)
sid
grayranger - '10 Ford Ranger XL 2 door supercab
90 day: 30.58 mpg (US)
I use foam pipe insulation. I feel the foam rubber type seals better than the flexible plastic foam. But it requires a lip on your topper, which all my toppers have had, to keep the foam in place.
2010 Ford Ranger, extra cab, 2.3 liter
http://www.stonemarmot.com
Band's latest song/music video "I Sing Along"
Old 09-25-2011, 11:20 PM   #6 (permalink)
That VX guy!
TomO's Avatar
The VX - '92 Honda Civic VX
Send a message via AIM to TomO Send a message via Yahoo to TomO
I believe this is the stuff that JRMichler is talking about:
You can use silicone caulking to keep it in place and even double it up where needed.
I've used it for sealing up gaps between structures before and smaller versions for ecomodding purposes on cars. It holds up to weather very well.
The Following User Says Thank You to TomO For This Useful Post:
Old 09-26-2011, 09:42 AM   #7 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Why not just use a bicycle inner tube? cut it into a straight tube if it's not otherwise large enough and seal off the ends, inflate it just a little so you can stuff it in place then inflate it more so it expands enough to firm up.
To cap the ends use rubber cement, jar lids and wrap it in thread to keep it from coming apart.
Old 11-04-2011, 07:48 PM   #8 (permalink)
How much of a difference does it make to fill in the cab-bed gap?
Old 11-04-2011, 10:54 PM   #9 (permalink)
Kodak's Avatar
Canyon - '07 GMC Canyon 2wd regular cab
90 day: 24.95 mpg (US)
I second using a flexible, forgiving material over a hard one.
EcoDriving: Turning more fuel into usable forward motion.
Old 11-14-2011, 03:28 AM   #10 (permalink)
EcoModding spendthrift
WindedWarrior - '12 Ford Focus SE
90 day: 33.46 mpg (US)
Back in 1999 I had a single cab f150 and a camper on back. I used an inner tube to seal the camper to the open cab window. This is a great idea and I bet it works better than the gasket you've sourced.
"May the wind always be at your back and the sun always upon your face. May the wings of destiny carry you aloft to dance with the stars."
~ Boston George
