Old 07-06-2010, 10:28 PM   #1 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Ultravan as a Dymaxion?
I saw an Ultravan for the first time last weekend.
It seems to be fairly aero. It is made out of aluminum and supposedly fairly light.
Some google image pics:
After cleaning up the body, get rid of the awning and A/C, it might make a reasonably aero shape. Maybe drop a VW TDI in there.
This could be somewhat close to a Dymaxion type vehicle. Except for rear wheel steering, which is better left alone.
Nissan Versa Aeromods
Old 07-07-2010, 01:37 AM   #2 (permalink)
Bicycle Bob's Avatar
Last 3: 42.35 mpg (US)
It lacks the gradual taper of the Dymaxion. Replacing the bubble back with a gentle taper and a kamm back would help a bit. The roof vents need fairing, too.
Old 07-07-2010, 02:14 AM   #3 (permalink)
Learning a lot
iplaysdrums's Avatar
Tony - '15 Honda Fit EX
90 day: 40.3 mpg (US)
The British say "aluminium."
I dig the built-in rear wheel skirts!
Old 07-07-2010, 03:21 AM   #4 (permalink)
Ehhhhhhh... Dymaxion like? Not so much.
Old 07-07-2010, 04:58 AM   #5 (permalink)
vectra a - '95 Opel Vectra GLS
90 day: 37.51 mpg (US)
compared to it's modern counterparts that's a thing of beauty! looks like a good starting point when all the junk on the top and the sides is shaved off.
that said it doesn't have a basic teardrop shape but rather rounded ends that works on the front, but it's less ideal at the back (think VW beetle).
this makes me wonder however...if you'd saw a Dymaxion in half and add a center section, limmo style, what would happen to the Cd?
aer·o·dy·nam·ics: the science of passing gass
*i can coast for miles and miles and miles*
Old 07-07-2010, 07:18 AM   #6 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
The rear shape may be better than many realize. Remember, it's a camper. It's not supposed to go 70 mph. 50-60 may be too fast to enjoy the ride. Think blue highways. The speedo may spend a lot of time between 30 and 45. When you slow down air softens, and sticks to sharper final tapers. That body transitions very smoothly. No first derivative discontinuities and second order looks very low. As for stripping creature comforts for a small MPG gain - phooey! Meet the functional requirements of the vehicle and it's intended purpose first. Not getting any sleep suffocating in your own sweat sucks the fun right out of travel.
Cheers
KB
Old 07-07-2010, 09:07 AM   #7 (permalink)
skyl4rk's Avatar
The tail end of the Ultravan is much wider than the Dymaxion.
However, the Dymaxion only seats four, while the Ultravan has much more interior room, enough to live in.
The Ultravans are relatively inexpensive and could be the base for an interesting ecomodmobile. However, they only come with Corvair engines and Chevy 350 V-8's, neither of which is a very good engine for fuel efficiency.
If one were to find an older Ultravan in rough shape, strip out and rebuild the interior to make it as light as possible, clean up the exterior and repower with a better motor, what type of mileage do you think it might get?
Old 07-07-2010, 09:30 AM   #8 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Clean up the exterior, or do a complete aero rebody with a narrow rear track?
I like boat tails, but putting heavy components in the tail moves the center of mass rearward with negative implications for crosswind stability and rear axle placement.
Old 07-07-2010, 09:32 AM   #9 (permalink)
Left Lane Ecodriver
Cd would increase as the relative size of its wake increases. Frontal area would increase as well.
Old 07-07-2010, 12:58 PM   #10 (permalink)
Patrick's Avatar
Hot Tamale - '10 Toyota Prius III
If you cut it at the maximum cross-sectional area, the Cd would rise a little due to inceased wetted area. You would, in effect, have made an aircraft fuselage. The frontal area would remain the same.
Buckminster Fuller's Dymaxion restoration botsapper General Efficiency Discussion 7 08-02-2023 01:43 AM
Which mass produced car is closest to a teardrop shape ? Cd Aerodynamics 125 10-26-2010 08:18 PM
Canadians make 4-wheel version of teardrop Dymaxion car in 1938 MetroMPG Aerodynamics 7 04-13-2009 11:36 PM
