Old 12-04-2015, 05:43 PM   #31 (permalink)
tabs
Originally Posted by cyclopathic View Post
I am not sure starting when but hycam and hy Avalon have little tabs under rear bumper. Prius C has 2 tabs on tail lights and one on mirror.
A lot of these are added after time in an anechoic wind tunnel,where wind noise was discovered.The tab changes the resonant frequency of the part,killing the noise,and very little is spent on tooling modifications to mass produce this change.
The EPA has stringent noise criteria for cars.Even tires.
Old 12-04-2015, 07:19 PM   #32 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 Mercedes Benz 300SD
90 day: 23.23 mpg (US)
Gentoo320 - '04 Mercedes C320 4Matic
90 day: 22.44 mpg (US)
One should note that noise takes energy to create
The Following User Says Thank You to ConnClark For This Useful Post:
aerohead (12-05-2015)
Old 12-06-2015, 02:19 AM   #33 (permalink)
Regular Camry has Cd .28 and hybrid .27:
2016 Toyota Camry Hybrid LE Specs, Options, Features, and Dimensions | Car.com
2016 Toyota Camry LE Specs, Options, Features, and Dimensions | Car.com
The Following User Says Thank You to cyclopathic For This Useful Post:
aerohead (12-07-2015)
