Old 02-22-2011, 11:43 AM   #1 (permalink)
Novice but learning!
Weight saving ideas
Ok, can anyone suggest any weight saving ideas that we might not of thought of? Maybe you will think different to how we do?
Thanks!
Old 02-22-2011, 12:54 PM   #2 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
- What is that shiny plate meant for in your exhaust manifold? I would also make the is it headers so that they dont penetrude so much out of the frontal area. Also if you make it closer to rear wheels you will get more grip.
- Do the series dictate that the rear wing has to be so high? If not lower the "brakects". Also I would close the gaps between those brakets on the spoiler if it is allowed.
- Can you adjust that front spoiler? It looks like its made from aluminium?, because there is so much rivets...
- Looks like your front brakes are regular steel brakes?
- Looks like you havent milled bolt heads shorter?
- What are those black hoses which go to your cam covers? Anyway you could mill some material off from that big blue anodized aluminium "bolt" Its over 80mm long?
- In my opinion your braided steel hoses could be shortened at least 10% by the look of you pictures.
Those are my suggestions.
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 02-22-2011, 03:31 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If you are serious about weight reduction, you could get another driver that has a smaller frame.
( I'm imagining something like a 98 lb 4'11" woman that likes to race :-) )
I'm sure you have considered that already though. Just thinking out loud.
Old 02-22-2011, 04:17 PM   #4 (permalink)
On one of my bicycles I took off everything that didn't make it go. Off came the smaller chainwheel, front derailleur, kickstand, rack, reflectors... everything except decals and handlebar tape. Look at the bits and think "do they make this thing go?"
Old 02-22-2011, 04:46 PM   #5 (permalink)
Braided steel hose is way heavy and I see tons of the stuff, lots way high on the chassis- consider hardlines for the majority of the length and smaller flexible connectors if nessicary. Things like dry sump lines or fuel lines that run between two components mounted on the block do not require any flex. Also give consideration to routing & mounting to save length. This exercise took about 10 lbs off our road racer.
Old 02-23-2011, 05:28 AM   #6 (permalink)
-Plate on headers is purely cosmetic, so we could lose it although its made from very thin ali so is very very light.
-No rules on height of the wing no, but were looking to move it further back.
-We are changing the front end to have a wing right across the front.
-Yeah front brakes are steel, we plan to skim and drill
-the blue bolt and housing are going they weight 2lbs each! were remaking very light weight versions.
-Good point, hoses can be shortened
Thanks!
Old 02-23-2011, 05:29 AM   #7 (permalink)
Haha good point!
Old 02-23-2011, 05:29 AM   #8 (permalink)
Have to admit since this photo we did that and lost 50lbs of weight. Well worth it
Old 02-23-2011, 03:34 PM   #9 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Are the headers angled upwards on purpose, like to produce downforce ?
If not, point them straight aft.
On WW2 fighter planes, using the exhaust cleverly gained them additional speed.
The exhaust is essentially a jet, generating thrust.
Old 02-24-2011, 04:07 AM   #10 (permalink)
Yeah to produce downforce but they are slanted back too,
