07-27-2011, 11:03 AM
Why the air dam lip?
Why do air dams have this lip? Is it needed or just aesthetics? When (if) I build my own, should I incorporate something like above or is better to leave it straight like this one below?
The Following User Says Thank You to BeatUpRanger For This Useful Post:
07-27-2011, 11:27 AM
They have them because NASCAR has them on lots of their cars. NASCAR has them for downforce. Effectively it is pushing the leading edge further forward and lower to the ground, forcing more air over/around the car, and allowing less under. It should be good for aero, but as all things aero, YMMV (literally!).
07-27-2011, 11:36 AM
Canyon - '07 GMC Canyon 2wd regular cab 90 day: 24.95 mpg (US)
From my understanding, it is to make it harder for air to get underneath the vehicle. I've seen some custom dams with it and some without. My plan is to include a small lip similar to stock design (just a lower dam).
Hey Ranger, if you build one will you post a little before/after thread?
I'm [very slowly] starting to finalize plans and collect materials for a dam. The more info the better.
EcoDriving: Turning more fuel into usable forward motion.
07-27-2011, 12:14 PM
Thanks for the info. That's good stuff.
I'd like to build one myself, but no that I won't be starting any time soon...although I wish I was. I'll definitely post pictures when I do. Right now she's plenty beat up (front end, driver's side fender and door) after a recent deer ambush. Once that's taken care of, I'll start on my eco-mods. So far, I've removed the mud flaps, and have been working on my own driving habits.
07-27-2011, 12:17 PM
It keeps the air on the air dam while it's being pushed outward to the sides due to the airdam's slight curvature.
Without a lip, part of the air that hits the airdam is still going to spill underneath the car - while airdams are used to reduce the air going underneath.
The Following User Says Thank You to euromodder For This Useful Post:
07-27-2011, 02:19 PM
While Googling images of air dams, I came across this racing page, which summarized a lot of the aerodynamic add-ons of performance cars.
Here's the link.
The Following 3 Users Say Thank You to BeatUpRanger For This Useful Post:
07-27-2011, 02:36 PM
Here's the link.
I didn't read everything on their page, but at least one thing I saw was wrong. Their graphic "Car Underbody Aerodynamics" shows air coming into the underbody as being "Fast Low Pressure Air" and exiting as "Slower Moving Higher Pressure Air". If the air is going slower leaving the diffuser (which we could reasonably assume) the pressure is lower, not higher. This is why diffusers generate downforce, they are being pulled down by the low pressure air.
Due to this oversight, just make sure you keep a cautious eye when reading people's aerodynamics pages, as it's easy to get thing wrong.
07-27-2011, 04:11 PM
Help me out, Wyatt. I didn't see what was wrong with the graphic. It shows that the air moving under the car is faster moving and lower pressure.
I thought that was Bernoulli's law: lower pressure causes fast-moving air.
07-27-2011, 04:15 PM
#9 (permalink)
About 2/3 of the way down the page, there is a picture of the underbody of a car. at the car's back end, it should say "Slower Moving Lower Pressure Air" (not higher as it does in the picture).
07-27-2011, 07:02 PM
#10 (permalink)
Yeah it's called a splitter and that's what it does
