Old 08-01-2016, 08:23 AM   #11 (permalink)
Red face Simple Fix for Heater & Over Heating Problem...
It appears it was an air lock in cooling system.
The mechanic apparently did not open or turn the bleed valve far enough to bleed the air out! After he turned the bleed valve open far enough with a 12mm wrench it started dripping coolant.
Then he slowly added coolant into radiator until it was finally burped of air.
After that was solved I checked the heater but still no heat!
So the mechanic checked the Heater control Panel by switching the heater control lever back & forth. The Heater Control cable became loose & detached itself, so he tweaked the cable with needle nose pliers to prevent the cable from detaching itself again.
Old 08-01-2016, 08:57 AM   #12 (permalink)
Originally Posted by ascendedmind View Post
4. Note: The top radiator hose gets warm, but not the bottom house. What does this indicate?
If the radiator hose that contains the thermostat is cold then it means the thermostat isn't opening. If it is hot and the return is cold then it means that there is no flow through the radiator. The fact that it started when you replaced the pump suggests an air bubble. Try starting the car (from cold) with the radiator cap off and let it run for 20 minutes or so until the thermostat kicks on. Bubbles will start to come up. You can rock the car back and forth to encourage bubbles to break free.
If this car has a sealed reservoir then check the reservoir lines (connected to the radiator cap) for any sign of cracks or leaks. Even a tiny hole will cause the coolant to steam out. This will reduce the pressure inside the radiator. Reduced pressure means lower boiling point, causing gradual temp rises.
The Following User Says Thank You to Poodwaddle For This Useful Post:
ascendedmind (08-01-2016)
Old 08-01-2016, 12:06 PM   #13 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Mystery solved, I even looked at pictures of the waterpump to see if any other problems were obvious.
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 08-01-2016, 12:13 PM   #14 (permalink)
Don't keep us in suspense. I really wanna know what the problem was.
Old 08-01-2016, 05:52 PM   #15 (permalink)
See post 11
Old 08-01-2016, 08:16 PM   #16 (permalink)
Poodwaddle, thank you very much for your sharing your knowledge, it has been very helpful.
Old 08-01-2016, 08:27 PM   #17 (permalink)
Like I said Poodwaddle the mystery was finally solved with simple fix revealed in post this morning.
1985 honda crx hf, aisin water pump, runs hot
