Old 10-11-2008, 03:51 PM   #1 (permalink)
Nerdcycle - '81 Honda CM400E
Motorcycle
90 day: 61.16 mpg (US)
Trouble - '06 Kawasaki Ninja
90 day: 74.69 mpg (US)
Edna - '13 Nissan LEAF SV
Last 3: 133.3 mpg (US)
Tank - '20 Ford Expedition Limited
Last 3: 17.4 mpg (US)
Why does the heater core transfer heat from the coolant, not the exhaust?
It would be hot almost instantly and would allow for an air cooled engine whose temperature could be controlled precisely by the amount of air that was let into the engine compartment.
The only reason I can think of is that it would be TOO hot, but that can be solved by just placing less heat exchange material on the pipe. It's probably be just fine to run the regular pipe through the airstream.
Old 10-11-2008, 04:02 PM   #2 (permalink)
roflwaffle's Avatar
Camryaro - '92 Toyota Camry LE V6
90 day: 31.12 mpg (US)
Red - '00 Honda Insight
Prius - '05 Toyota Prius
3 - '18 Tesla Model 3
90 day: 152.47 mpg (US)
Too complicated is my best guess...
Old 10-11-2008, 04:30 PM   #3 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
If it leaks, it's poisonous gas leaking in the cabin versus engine coolant
That, and it's a whole lot easier to route a relatively clean liquid than a much hotter gas
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 10-11-2008, 05:17 PM   #4 (permalink)
Mechanical Engineer
The Truck - '02 Dodge Ram 1500 SLT Sport
90 day: 13.32 mpg (US)
The Van 2 - '06 Honda Odyssey EX
90 day: 20.56 mpg (US)
GoKart - '14 Hyundai Elantra GT base 6MT
90 day: 30.31 mpg (US)
Godzilla - '21 Ford F350 XL
90 day: 8.69 mpg (US)
trebuchet hit the nail on the head....toxic fume leaks.
Old 10-11-2008, 05:28 PM   #5 (permalink)
Why don't they run an absorption cycle A/C from it?
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 10-11-2008, 05:43 PM   #6 (permalink)
MechE
I've been curious of the same thing for a few years now.... But I haven't educated myself enough on the concept to build one myself
Old 10-11-2008, 06:00 PM   #7 (permalink)
I have a number of vehicles where the cabin heat is gotten from exhaust heat exchangers and/or from cylinder waste heat (VW, Corvair, general aviation aircraft (but I don't own one now)). That system can be great WHEN EVERYTHING IS IN PERFECT WORKING ORDER. But, reality interrupts our little daydream (doesn't it always?). Over time exhaust systems rot out and yes, noxious fumes come into the cabin. Also, when (not if) there is an oil or gasoline leak in or near any component of this sort of heating system, all that stench comes in the cabin too.
Old 10-11-2008, 06:09 PM   #8 (permalink)
Puddles - '95 Geo Metro LSI
90 day: 39.52 mpg (US)
Spec Miata - '91 Mazda Miata Club Racing
Scooter - '05 Honda Metropolitan
Monstro II - '99 Dodge Ram 1500
Kassia - '01 Mazda Miata LS
Precious - '97 Chevy 3500 Silverado Dually
both good answers, I will also add.
-heat is exchanged easier, and more efficiently in a fluid
-antifreeze has an anti corrosive that should ideally keep the system working properly longer
-exhaust is wizzing out of your car as fast as possible, back pressure makes your car perform less goodish, where as the radiator fluid is restricted/slowed down by the therm to make the engine coolant exchange work better, and it doesn't _really_ effect engine performance.
Old 10-11-2008, 06:13 PM   #9 (permalink)
Fire: I disagree with your points 1 and 3. Experience shows those not to be factors.
Old 10-11-2008, 06:23 PM   #10 (permalink)
That's assuming that you and I agree that VW and Porsche heaters are sufficient. We don't.
glow plug based coolant heater Coyote X EcoModding Central 23 09-11-2018 06:36 AM
Converting Exhaust Heat to Electricity SuperTrooper General Efficiency Discussion 13 03-20-2010 06:03 AM
Waste Heat from Exhaust TES111 EcoModding Central 35 11-21-2008 12:31 PM
Steam engine (from exhaust heat) iHero General Efficiency Discussion 23 09-08-2008 12:30 AM
850 watt tank style coolant heater - installed in the Blackfly MetroMPG EcoModding Central 4 11-28-2007 02:10 PM
