Old 11-16-2008, 10:34 PM   #31 (permalink)
Silver EP3 - '02 Honda Civic Si
Originally Posted by Cd View Post
So if I understand correctly, braking has no effect on FE. It is just the fact that you are wasting your momentum and having to rebuild it up again once you apply the brakes.
Just as I thought. ( Seems like common sense really )
To us it does! I watch so many people, with automatics ride each others bumpers, and brakes like crazy. It just drives me nuts! When I first realized that also, I thought of it as conserving momentum...
Old 11-23-2008, 06:11 PM   #32 (permalink)
Ezcape - '15 Ford Escape Titanium
90 day: 19.89 mpg (US)
Dale Jarrett commentating in the ESPN booth at the Bristol NASCAR race in 2007; "The biggest fuel waste is that pedal right in the middle"
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
https://ecomodder.com/forum/em-fuel-...ehicleid=10608
Old 09-07-2014, 07:47 PM   #33 (permalink)
SilverCrown9701's Avatar
SilverCrown - '01 Toyota Camry LE
90 day: 35.32 mpg (US)
As a Hypermiler, you want to learn to "drive without brakes"...meaning use just enough acceleration and coasting to get you between stops on your destination. If you have to constantly brake hard between starting and stopping then you are over accelerating and under coasting.
However, "hard braking" has its place. The entire basis of hypermiling is to maintain as much momentum as possible. Let's say you are driving 45 MPH and the light ahead is still green...then all of a sudden, it changes to red. You quit accelerating and begin coasting but you realize that you're still going too fast and will have to stop ahead. INSTEAD, you can "brake hard" with a few hard brake pulses, reducing your speed to 25-30 MPH. You can extend your coasting time and hopefully make it through the light.
It takes much less energy to accelerate from a few MPH versus a dead stop. You also have to keep in mind your SAFETY and the wear and tear on your vehicle.
Braking hard and taking sharp turns at higher speeds increases wear on your suspension, tires and brakes. It also causes the gasoline to splash around inside your tank, which can offset your numbers.
All of this takes patience, timing and practice but once you master them then you will be that much better a driver.
Remember...NEVER ever risk your safety or your vehicle for a couple more MPGs. Your life is much more valuable than fuel economy.
The name "Camry" is an Anglicized phonetic transcription of the Japanese word kanmuri meaning "crown".
Old 09-07-2014, 09:23 PM   #34 (permalink)
...beats walking...
Think about the following events that occur when BRAKE is pressed:
• DISTANCE coasting is reduced.
• TIME engine not loaded is reduced.
• MOMEMTUM is being converted into HEAT (by brakes).
Old 09-07-2014, 09:43 PM   #35 (permalink)
I completely agree. Momentum should always be the first on a hypermiler's list. The less you have to stop, the more efficient your results. My only point was when faced in a particular certain situation, never compromise safety or the well being of your vehicle for fuel economy.
Keeping this in mind will make you a more conscious and efficient driver by ensuring that you take the additional care to give yourself plenty of space, time and patience.
Old 09-07-2014, 10:54 PM   #36 (permalink)
XYZ
A Q&A:
Why is hard braking bad?
Because it stresses and degrades your brake drums and shoes and/or disc pads and rotors faster than soft braking does. Your brakes will wear faster and that sucks $$$ out of your pocket faster. So don't make a habit of doing it.
Some of us here are only interested in saving fuel, at any cost. Some of us are primarily interested in saving $$$. Some are interested in both. It's your car, your money, and your choice.
Is all braking bad?
As others have said, all braking does is that it simply reduces momentum. A hypermiler's wet dream would be never to have to brake at all. But that's a fantasy - it's not real life in the real world. So let's be realistic and compare braking to '"when nature calls": when you gotta go, you gotta go. And when when you gotta stop (immediately, as in emergency situations) stopping is much better than NOT stopping.
The Following User Says Thank You to XYZ For This Useful Post:
SilverCrown9701 (09-08-2014)
Old 09-08-2014, 12:08 PM   #37 (permalink)
Metro mentioned the numbers game. When I drove Bacon, if I needed to stop while on a road trip, I shifted to neutral and waited it out, but when my Ultragauge showed GPH below my overall goal, I came to a stop and turned off the engine. It has an automatic transmission, so EOC was not an option. It was frustrating because I wanted to use the last of my momentum, but it just did not seem worth the fuel used while idling.
Fuel Economy related papers tasdrouille General Efficiency Discussion 41 03-19-2021 06:31 PM
Lugging the engine - good or bad for economy? landspeed General Efficiency Discussion 28 05-23-2014 11:03 AM
Crashing is real bad for fuel economy SVOboy EcoModding Central 15 06-30-2008 09:59 AM
The New York Times: Economy Champs Get the Cold Shoulder akcapeco EcoModding Central 4 06-14-2008 12:42 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
