Old 03-18-2010, 11:40 PM   #11 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
Falling trees is a concern. I've been thinking about a crash-bar across the top.
However, I had the 10.5 foot mesh dish there since the early 80s and it hardly got a ding..
The only real damage to the structure was from ice expansion inside
a few of curved support arms. They were hollow and held water..
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 03-19-2010, 03:11 PM   #12 (permalink)
Originally Posted by chaster View Post
Good points. The question in my mind is the magnitude of the interference drag..
Eric,if you'll go up to the search-engine,top-left of forum page,type in FLOW-IMAGES(brain food) and go to Photo Gallery-7,second row,2nd image from right.
There is a depiction of a flat plate and the magnitude of the separation and wake area.
Your panels,even if spaced at large distance to one another would still be 'inside' the wake of adjacent panels.
I'm no pro.I have done professional installs with an area photovoltaic business.They always gang the panels together onto the smallest footprint,for fixed arrays,and also tracking mounts.Nearly every home where I live has PV and we all go for the minimums with respect to spacing.
Keeping the load concentrated near the center reduces what otherwise could grow to enormous torque,as loads are applied along very long moment arms.
Old 03-19-2010, 03:36 PM   #13 (permalink)
I wasn't doubting that there would be interference effects. I was just wondering what the *magnitude* of those interference effects would be.
I agree with your predictions of torque load on a single pole mount.
Eric
Eric Cha
Xenopi Studios
Check out the xenoDisplay and the SPARC XEV!
Old 03-20-2010, 03:55 PM   #14 (permalink)
magnitude
Eric
Eric,if you need a specific load for a given spacing,I would not be able to provide that,as I do not possess data from heliostat research conducted in windtunnels.
What I would pose to you,is to imagine a PV array,with the panels spaced far enough apart,that there was no aerodynamic interaction present if you will,and the scale of such a support structure necessary to allow this condition,then any possible benefit from a structure so large as that,when common engineering practice dictates that we use the minimum amount of material for any given solution.
Old 03-20-2010, 04:09 PM   #15 (permalink)
Somehow, I get the feeling you are interpreting my statements as an argument or disagreement when they are not. I didn't request "specific load" data, nor was I expecting it...
The OP was asking a general question, my opinion is that "it depends". It's not an argument.
Eric
Eric Cha
Xenopi Studios
Old 03-20-2010, 04:57 PM   #16 (permalink)
interpreting
Eric
Eric,no,I'm okay with your statement,it's just that 'magnitude' inferred some kind of quanta,and I'm just not up to the task on providing meaningful data.
It's a good question.
One of the first projects for the Texas Tech Aerodynamics Lab was heliostat research for solar farms,which might have addressed the interference issue.I suspect it did.
The 'scope' of what they were doing seemed beyond the domain of the individual,so I didn't pay much attention.
It would be of value now as it is germane to PV installs.
Old 06-23-2011, 02:21 PM   #17 (permalink)
Crash!!!
Story here:
Solar Tracker Project - Page 18 - EcoRenovator
Cheers,
Rich
Tire Wind Deflector Question alohaspirit Aerodynamics 33 03-26-2012 02:54 AM
New Generator Wind Turbine Efficiency 50%+ Funny Saving@Home 17 03-09-2010 05:13 PM
