Go Back   EcoModder Forum > AltModding > Saving@Home
Old 08-31-2017, 07:21 PM   #11 (permalink)
mild-mannered civic - '97 Honda Civic LX
90 day: 32.56 mpg (US)
+1 for the solar tint.
Made a HUGE difference for me in the summer time.
Old 08-31-2017, 07:53 PM   #12 (permalink)
Even though I currently live in an apartment, and finding suitable double-paned windows for it is not so easy back here, it's something I do consider to use whenever I move to a house. Other energy-saving features would also not be out-of-question.
Old 09-20-2017, 02:21 PM   #13 (permalink)
Sorry I did not post this earlier, but I think that for some applications, glass brick make sense. What is the R-value?
The R-value for Premiere Series glass block is 1.96, which is more than twice the value for flat 1/8" sheet glass windows or roughly equivalent to a double pane thermal window. The ThinlineT Series R-values are slightly lower at 1.75.
Glass Block Sales, Inc.
Have a great day!
Old 09-20-2017, 02:41 PM   #14 (permalink)
Plus which it's structural. Offsetting that it would cost more, I suspect, than double-pane glass.
Old 09-20-2017, 10:54 PM   #15 (permalink)
The problem with glass brick is that it won't open like a regular window would. But anyway, considering that it would provide enough luminosity and allow the use of smaller windows, might offset the cost.
Old 12-10-2017, 02:47 PM   #16 (permalink)
phys.org:Solar power advances possible with new 'double-glazing' device
cleantechnica.com:Scientists Channel Tesla & Einstein To Invent New Double-Glazed Solar Panel
Two sources so you can compare the reporting. I like both but generally prefer phys.org; they're usually out front. In this case 2 days earlier and include a journal reference in addition to U of Warwick.
Anywho, this is Steampunk Stuff. Two transparent surfaces, one electrically conductive and one with a sputtered coating of [diamond] with the cavity filled with argon.
This is low-rent high-tech.
Xist (12-10-2017)
Old 12-11-2017, 10:42 AM   #17 (permalink)
Even though that would lead to overall savings in utilities cost, nowadays with all that "sustainability" trend I'm sure it could serve as an excuse for landlords to increase the price of a rent
But anyway, if I were going to build a new house, or eventually refurbishing an older one, I'm sure I would look at some options on "efficient" windows.
Old 12-11-2017, 12:04 PM   #18 (permalink)
90 day: 29.78 mpg (US)
Landlords don't care about efficiency, which is why apartments are very inefficient. They build the units to minimum legal standards of efficiency.
The new place I'm at has front doors you can see light coming from around the edges, and some doors are so poorly placed you can see into the home.
Old 12-11-2017, 01:08 PM   #19 (permalink)
By low-rent I meant to imply low-cost or home-brewed.
I was thinking of a 'post apocalyptic' or maker-scene scenario. Maybe I should have emboldened steampunk.
Old 12-11-2017, 01:31 PM   #20 (permalink)
Thalmaturge
CHONK - '18 Honda Clarity
If you want low-rent double-paned, then you probably just want this ;-)
https://www.walmart.com/ip/Duck-Bran...-Pack/17510819
