Old 11-01-2009, 06:23 PM   #11 (permalink)
I used to have a 3.5 HP rototiller engine that had been re-tuned to run Kerosene. It ran a water pump, it was amazing how long it took to burn a gallon of fuel through that engine, but it did smoke a little.
Dave
If it has a motor its worth playing with.......
Old 11-01-2009, 09:16 PM   #12 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Dave
Dave -
There is a section in the shop manual for older Briggs and Stratton motors that details how to convert the gasoline engines to run on Kerosene, which can actually then be converted to spark-ignited diesel, thus making them capable to be run on HomeBrew BD!
Old 11-07-2009, 02:35 PM   #13 (permalink)
Opel/Ford/Mercedes
Military history book catalogs will have illustrated books about the WW-II German vehicles available.The books I have on Opel/Ford/Mercedes have very clear photographs of the wood-gas units.They may have technical info on construction/operation/efficiency,don't know at present as I was interested in other aspects of the vehicles.
I suspect Japan had similar tech,as they were doing technology transfer with the Third Reich and were also running out of petroleum,ending up digging pine roots for fuel.
Old 11-07-2009, 04:24 PM   #14 (permalink)
In Lean Burn Mode
pgfpro's Avatar
MisFit Talon - '91 Eagle Talon TSi
Team Turbocharged!
90 day: 63.95 mpg (US)
Warlock - '71 Chevy Camaro
Fe Eclipse - '97 Mitsubishi Eclipse GS
Thanks for the good info!!!
Pressure Gradient Force
The Positive Side of the Number Line
Old 11-07-2009, 05:59 PM   #15 (permalink)
jmf
blueberry - '93 honda civic vx
90 day: 55.24 mpg (US)
I ran my 97 dodge on wood-gas last year. I mounted the gassifier on the front and got a lot of crazy looks.
[IMG][/IMG]
Old 02-18-2010, 01:38 AM   #16 (permalink)
fidalgoman's Avatar
A number of years ago Popular Mechanics ran about an 80's Malibu wagon with a gassifier unit mounted on a trailer. They went across country from New York to California using only free construction wood scraps. Ash in the gas required them to change their oil often, but other than that there were no problems.
By the way these units can be made to run on coal as well. The more successful units had a gas scrubber to remove the particulate matter and thus solve the ash problem. This can be in the form of an element filter or as simple as bubbling the gas through a water maze. The Russians continued to use this technology many years after WWII because it was cheap, it worked and they had little in the way of fuel production or distribution infrastructure. The manifold mechanism is similar to using propane, NG, etc.
It does require you to bring the gassifier up to operating temperature before taking off so those five minute jaunts for a gallon of milk might take more like twenty or so. For those homesteader types it makes a viable electrical alternator fuel source for living off grid.
Old 02-18-2010, 01:45 AM   #17 (permalink)
Any way to make the gas and store it to be used later? We have lots of trash/debris/clippings/etc. that get burned and nothing ever comes of it except smoke. It's terrible, really. I would love to be able to make something of it and save it for future use, if at all possible. If not, I guess a gas-making-thingy might be a good idea to make/store electricity anyway, eh?
Old 02-18-2010, 02:51 AM   #18 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Toyota Echo 4D Auto
90 day: 34.45 mpg (US)
New Galaxy - '07 Toyota Prius
90 day: 42.15 mpg (US)
ill think about it when it gets this big
Past Present Future?
Old 02-18-2010, 07:43 AM   #19 (permalink)
jmf
You can only store the gas in it's wooden form. A pound of wood takes up a lot less space than a pound of gas and is a safer way to store it.
Old 02-18-2010, 08:40 AM   #20 (permalink)
Maroon Ballon - '98 Chrysler Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Geo Metro 5spd hatch, 3 cyl
[IMG][/IMG]
Do you have some details on your gasifier?
I experimented with different configurations of soup can sized gasifiers last summer for camp cooking. They used pencil sized twigs, and I was amazed at how much more efficient they were than building a campfire for cooking.
Hyperinflating tires CapriRacer Hypermiling / EcoDriver's Ed 276 03-14-2022 03:51 AM
Registering a car based reverse trike in CA Carwhisperer EcoModding Central 58 07-10-2011 07:12 AM
New CVT transmission electric-assist with electric assist Ptero Fossil Fuel Free 2 09-23-2010 10:41 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 01:57 PM
CA Vehicle Code - Mirrors thebrad Aerodynamics 2 08-30-2008 11:03 PM
