Old 03-04-2011, 08:40 AM   #21 (permalink)
Remember that your body is quite draggy - tight leathers will get you a bit of an improvement over floppy textiles.
Carefully remapping the FI system is nearly always good for a significant improvement.
The aero stuff should help.
Riding slow will help a lot
Make sure the engine temp stays above 180 deg F.
The Following User Says Thank You to bikepilot For This Useful Post:
kawboyCAFE (03-05-2011)
