A8 1.2TDI is alive registered and running lean
1997 Audi A8 1.2 TDI 6 speed manual Gas Mileage (A8 luxury fuel sipper) - EcoModder.com
Very good result in my first calculated "tank". 5.62 L/100 km 41.9 mpg (US) 50.27 mpg (Imp) 2.39 gal (US)/100 mi 804.38 Wh/mi https://scontent-arn2-1.xx.fbcdn.net...3f&oe=56466B92 |
Congratulations on this epic conversion! You always have interesting projects but the work involved is a testament to your ingenuity and tenacity. Would the Audi be about the same weight as your Passat now? I think the 1.2 TDI is about 250 pounds so did the car loose about 200 pounds after the conversion? I bet the handling is much better now.
Good to see this project up and running :D
I wonder if a 1.2 is actually too small and running high loads means richer AFR's? |
That's an epic project anyway.
That's an awful lot of mass to tow around with a 1.2. I reckon once it gets up to speed it isn't too bad though. God knows the TDI engines make good torque for their size, if you have the time I don't doubt it'll accelerate up to highway speed eventually.
Have you done any aero mods to ease the engine's workload at cruising speed? |
Well, nowadays that Ford uses a 2.8L turbodiesel in the Brazilian version of the F-350, let's give some credit to the 1.2L in Vekke's A8.
Second tank data are ready, so took some trip as weather was very warm in this summers scale on Finland +25 celsius in the evening and +17 on the night at the moment.
4.24 L/100 km 55.55 mpg (US) 66.66 mpg (Imp) 1.8 gal (US)/100 mi 606.69 Wh/mi Had 50 km of traffic light driving in the beginning of the tank. Cam timing is now adjusted from -2.2 degrees to 0 degrees. That seemend to help quite much specially to low end torque. Rest of the tank tried to drive 100 km/h avg speed as much as possible. AVG temperature +22 celsius. Measued odo trip error to be 1% so that is now corrected. Speedo error is -6% which is also corrected for the avg speed. Lot of black smoke is coming on bigger uphills so the ecu tuning is still way off before its fixed to this turbo and car. One driver opened his window on highway and warned that is my engine OK due to that smoke. I would not say this is slow already at current state, even its not working perfectly yet ;). Weight of the car is 1430kg at the moment plus driver which in my case is +100kg. With current level of fuel I would say under 1600 kg easily total in driving condition. |
