EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   ? about wheel covers (need to preserve access to hub locks) (https://ecomodder.com/forum/showthread.php/about-wheel-covers-need-preserve-access-hub-locks-26039.html)
aktacoma 06-01-2013 04:11 PM
so I want to do pizza pan covers for my tacoma however in the front to use the 4 wheel drive I have to lock my hubs and that requires access to the front wheels. so has anyone figured out what to use? I want to cut a hole in the pans so i can stick my hand through and lock the hubs but am wondering what i should use to cover the holes and keep my aerodynamic resistance to a minimum??:confused:
Rango318 06-01-2013 04:57 PM
Would there be a way to attach the covers to the actual lock so you can turn the pizza pan to lock and unlock the wheels. If so you could just have a small hole, as to use some sort of removable handle in the hole. (sorry i'm not doing the best at describing my ideas)
aktacoma 06-01-2013 05:06 PM
No I understand however I want to make sure that the hubs don't lock in without me knowing because that can screw up your front drive components if like one was locked in and one was not. The tool idea is good but sometimes I'm on the road and I need the hubs so I jump out quickly and fumbling with a tool at -30F is not my idea of fun haha
Rusty94cx 06-01-2013 05:29 PM
Why not tiny holes and zip toes to hold the pans on. Always carry extra zip ties and presto.
aktacoma 06-01-2013 06:26 PM
no thats what i plan on doing but i dont want to have to yank the whole pan off when i need to lock the hubs each time I need the 4 wheel drive:o
NachtRitter 06-01-2013 07:02 PM
Rubber grommet?
http://www.hometech.com/hts_images/su/su-saegmt8_1.jpg
Get one with a small hole in the middle (I've also seen some with "pizza slice" cuts) so you can get a grip on the grommet to pull it out when you need to... the small hole would have essentially no effect on the FE.
One of the papers linked to on here also indicated that having "donut" shaped wheel covers (that is, a ring with a hole in the middle) has minimal disadvantage compared to a solid wheel cover... meaning you could just leave the hole uncovered and still gain nearly all the effect of a solid cover. Unfortunately I couldn't tell you which thread this information was in.
aktacoma 06-01-2013 07:12 PM
thats exactly what i was thinking except i didnt know the exact name for them!! where did you find solid ones though??
Sven7 06-01-2013 07:20 PM
You could mount the covers onto snap-on autozone wheel covers, and pull the things off when you need to get in there. Or you could buy two flat-faced wheels for the front and forget about wheel covers.
NachtRitter 06-01-2013 08:55 PM
Google-y... :) Searched for "rubber grommets" and then looked at the images to find what I thought would work. The image I linked was from here: Suttle SAE-GMT8 Rubber Grommet Kit (8 pack) - HomeTech Solutions
Another thought is to use the metal grommets such as this:
http://images.lowes.com/product/conv...36385816lg.jpg
That one I found at Lowe's on-line.
Rokeby 06-01-2013 09:07 PM
Originally Posted by NachtRitter (Post 374211)
...One of the papers linked to on here also indicated that having "donut" shaped wheel covers (that is, a ring with a hole in the middle) has minimal disadvantage compared to a solid wheel cover... meaning you could just leave the hole uncovered and still gain nearly all the effect of a solid cover. Unfortunately I couldn't tell you which thread this information was in.
Is this the one?
Drag Reduction Through Wheel Design
