Accurate instrumentation possible on a diesel?
In another thread, rmay635703 said:
I'm using MPGuino on Berta, but it has FE signal comming out of ECU, so it was easy to make it work.
Electronics made the things easier regarding fuel-efficiency instrumentation in Diesels, but with an old-school one it's still a challenge...
The 2014 Cruze Diesel has the same MPG display as its gasoline counterpart...and it just counts the number (and thus volume) of injection squirts (the diesel uses more than one) to estimate diesel consumption.
The promotional material for the ScanGauge II indicates that it supports diesels. Is that just wrong? Or is there something about my truck that's unsupported. Still confused here...
I have a ScanGauge II on my 2000 Jetta TDI and it does a reasonably good job of estimating the fuel consumption. Not perfect, but good enough to know how well I did on a commute or an errand. I normally run B20, and when I change to pure dino-diesel, the SG will get confused and will be off by a several MPGs. You can check out my fuel log; I've started to include the SG results with each fillup.
In a Mercedes OM 603 engine, there is a EDS control unit that is supposed to control the amount of diesel to be inyected by injection pump.
I have EDS scheme diagram. One should take advantage of it and construct a math model that calculates diesel fuel used, and together with speed, calculate mileage. |
