ACM board much better than coroplast
For those in range Ive found ACM for $40 a sheet in ATL. GA.
it is sandwiched .07 aluminum sheets with poly center, not much more weight than coroplast and much more durable and attractive. Atlanta Specials :thumbup: |
"prices valid through march 31, 2013!"
ok........how bout you spell out ACM.
Since after a quick search (link was to a home page NOT the exact product) I have no idea what I'm looking for. also, how about some pics? 4ft x 8ft coroplast is $19 |
48 in. x 96 in. White Cap Corrugated Plastic Cardboard (10-Pack)-WC4896-10 at The Home Depot Thanks to KamperBob http://ecomodder.com/forum/showthrea...tml#post367796 In http://ecomodder.com/forum/showthrea...ast-12100.html, Cd said "If you want cheaper Coroplast, try your local recycling center. It's FREE" |
Honestly, I have been wondering who actually uses ten sheets, three hundred and twenty square feet, ever--besides politicians. I guess that if your plans require seven sheets, which you could get for nineteen dollars each, you might go for it. :D |
lol
I believe ACM is Aluminium Composite Material, but I do not know wnything about it - personally.
PolyMetal
Available through my local distributor, Multicraft Plastics, for three different prices depending on whether you present yourself as a wholesaler, business or individual. :rolleyes: I've worked with samples. It's available in 4x8, 4x10, 5x8, 5x10 [project sized] pieces. Also, see: Alumacorr vs. Poly-metal |
