Active grill shutters at the dollar store!
4 Attachment(s)
These vents have a pair of plastic shutters that are actuated by a small DC motor. Perfect for an automated grill block! But being a motor, they need only a short electrical pulse to move. You can't feed them continuous power. The timer takes 2 AAA batteries, so I assume the motor gets about 3 volts. It works fine on 1.2v. I wouldn't try 12v! Some weatherproofing for the motor will be necessary. The shutter area is about 4" x 9". I'll try one first, maybe that'll be enough airflow. I usually have a smaller grill opening than that.
I bought a bunch. I'll make a post in the classifieds if anybody else wants to play with one. Or if you're in Upstate NY, look for Real Deals Dollar Stores! http://ecomodder.com/forum/attachmen...1&d=1410546385 http://ecomodder.com/forum/attachmen...1&d=1410546385 http://ecomodder.com/forum/attachmen...1&d=1410546385 http://ecomodder.com/forum/attachmen...1&d=1410546385 |
Nice find! I wanna see them on your car now. :)
http://www.amazon.com/Vent-Miser-91663-BR-Programmable-Energy-2-Inches/dp/B000WAGVRY
$7.89 for 2" x 12", $5.99 + $2.99 shipping for 4" x 10" |
1 Attachment(s)
http://ecomodder.com/forum/attachmen...1&d=1410549719 |
If I buy you black paint, will you use it? :D
That's f#$%ing perfect! It's pretty much as I had envisaged fabricating. Sooo much easier to use off the shelf parts.
I think it will be better without the white vent cover and with a fabricated duct. A regulated 3V (from "12V") is almost trivial to achieve. I'm also thinking an aero profile on the blocking slats for when they are open :). And, can something useful be done with the timer/clock? |
Interesting..... And someone on kick starter had one that you operate by bluetooth. Sounds like too much work, Ill stick to my little 4x4 inch opening. :thumbup:
I wonder if one of those would provide enough airflow for a 2000 insight in 104F Weather fully opened? This definitely is worth looking into if I can get my overheating problem fixed.
For hotter climates, I'd probably use two of them.
