Active Trailer gap for Tractor Trailers
Here is an interesting product from a company call Truck Wings. It is an active cab deflector that folds out at speed to close the cab to trailer gap and then folds again a low speeds so the truck can turn. They claim a 4% increase in fuel economy with is huge for a on-highway truck.
https://www.fleetowner.com/equipment...or-trailer-gap https://secureservercdn.net/198.71.2...nal-C10-03.jpg |
The savages allowed into this country always find a way to destroy stuff in new & imaginative ways. This wouldn’t be an exception unfortunately.
But I sure wish I’d had a gap closure system on the 579 Pete EPIQ a few days ago running out of ABQ thru OKC: 41,000-lbs in the box, all the way to the doors; had the tandems back a little farther than allowed; trailer has the full skirts & tails treatment. I keep the kingpin forward of center as the front axle rating isn’t taxed. 76,700-lbs. Gap is well under 30”. Had my tail kicked the whole way in this new tractor (80k) by the crosswinds. Were the windmill gensets turning? Ha! Hardly. I’d have been happy to have had that additional help. Stayed at 8.3-mpg with PACCAR 13L + 12-AMT at 66-mph. Reducing driver fatigue rates as high or higher than a few tenths. One wears down early in the day. Now, if only the industry would develop & market a shock absorber that wasn’t gone by 30k. The gas charge is GONE by that point. Body roll and wind twitch gets real real old, real real quick. Boutique shocks ain’t gonna happen. Thanks for posting. . |
Looks interesting but wish there was a passive device that could net similar results.
UPS gets a lift as TruckWings eliminates the tractor-trailer gap https://www.fleetowner.com/equipment...or-trailer-gap https://www.fleetowner.com/sites/fle...?itok=Mos9pUmI Quote:
https://ecomodder.com/forum/showthre...-35653-41.html Quote:
I wonder if there is any collaboration with Xstream Trucking as shown in the very first image in this thread. I do not see them listed as a partner. FYI: Video below of the wings in action, looks very simple, easing any misforgivings I may have initially had. XStream Trucking - TruckWings https://www.youtube.com/watch?time_c...ature=emb_logo Quote:
XStream and Flow Below aren't connected that I know of. The only thing that concerns me about the Truck Wings is the use of air cylinders for activation. Yes, they are cheap but it is hard to keep multiple cylinders in time without constant fiddling.
The Flow Below product does work but the universal mounting kit is a bit of a pain. It is good to see they are offering some truck specific options. |
Why can't a semi use a simple gap filler that goes a bit down the side of the trailer and be spring loaded so it flexes out in a turn and returns to center. You might have to also tie both sides together so the outside fairing also pulls away in a turn so it doesn't bind as the trailer comes into place. Basically like gills of a fish.
Flow Below works well with vans. My company grown tired of repairing tails/skirts, but FB a priority.
As a note, too many of y’all have the wrong idea about aero. Straight-ahead forces are almost self-equalizing. Not that important compared to crosswinds. A tall vehicle with high COG and enormous sail area (the trailer skin is larger than your house) has other worries. Straight ahead is easy. Any vehicle. Now, ask a pilot about crosswind landings. . |
A big issue for aero on tractor trailers is that most of the time the tractor and trailer aren’t owned by the same company. The trailer owner has little incentive to spend money to reduce someone else’s fuel bill. They just want a cheap generic box trailer that any tractor can transport. Likewise a truck owner can’t make mods that limit the types of trailers he can tow. Edit: The truck also can’t be more than 102 inches wide and trailers are already that wide on the outside. Your typical trailer is 99 inches wide inside so you can put two 48 inch pallets side by side. That leaves an inch on each side and an inch between pallets for room to maneuver them. |
down the trailer sides
MIT and NASA engineers demonstrate a new kind of airplane wing Assembled from tiny identical pieces, the wing could enable lighter, more energy-efficient aircraft designs. David L. Chandler | MIT News Office March 31, 2019 MIT and NASA engineers demonstrate a new kind of airplane wing | MIT News http://forums.pelicanparts.com/uploa...1574294406.jpg Quote:
http://news.mit.edu/sites/mit.edu.ne...?itok=89R5nN1- Quote:
