EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Adding a VSS output to a Mechanical Speedo (reed switch) (https://ecomodder.com/forum/showthread.php/adding-vss-output-mechanical-speedo-reed-switch-22110.html)
meelis11 06-01-2012 05:44 AM
Just made a quick search and maybe this link is helpful to people who only have mechanical speedo and want VSS output to mpguino...
Edit: some more stuff from same forum:
http://www.speedview.co/forum/Forum-Tech-Info
Wild_Doogy 06-12-2012 12:57 PM
Awesome find, I will need to do that when my unit arrives. I am guessing I won't need a converter board between the reed switch and the MPGuino, and that if I do, I can modify the source enough only need a simple one.
~Wild_Doogy
Edit:
I found that my speedo already has a reed switch so I just brought some wires off the back and hooked them up to my MPGuino. I am not sure where the error is, but I did notice an occasional error in my speed readout where my speed seemed to double, but that sounds like a double pulse.
