Old 06-18-2009, 04:27 AM   #1 (permalink)
UfoTofU's Avatar
UfoTofU - '91 Honda CRX DX
Last 3: 28.36 mpg (US)
Change idle RPM
Is it possible?
Old 06-18-2009, 07:49 AM   #2 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 40.29 mpg (US)
Originally Posted by kitaimdao View Post
Is it possible?
Certainly. On a carburated car there is usually an adjustment on the carburetor. On a fuel-injected car you're looking at getting a tuning module, which ain't cheap, if it's even available.
Old 06-18-2009, 11:49 AM   #3 (permalink)
Eco Dreamer
Versa - '08 Nissan Versa SL Hatchback
It should be possible with most any car. I have a 05 nissan frontier (obviously fuel injected and computer controlled) and there is a weird turn key, press gas 10times, turn key, stomp on brake peddle a few times, etc etc and it resets the idle to stock.
I found my idle creeped up about 100rpm above stock.
Also, if you want it lower that stock (which will probably make the car vibrate) the dealer CAN do it, but unless you have an 'in' I doubt you will find one that WILL do it.
Old 06-18-2009, 11:54 AM   #4 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
My tbird and capri have adjustment screws on the throttle body. Depends on how old or new your fuel injection system is. Thats just for base idle though. You have to usually ground a certain wire to set it. After that computer and IAC take over.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 06-18-2009, 12:38 PM   #5 (permalink)
McTimson's Avatar
Maverick - '22 Ford Maverick XLT
90 day: 40.02 mpg (US)
My Tercel just has an easily accessible screw in the throttle body. You can raise and lower it however you like.
Old 06-18-2009, 01:54 PM   #6 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
My Peugeot seems to have two idle speeds: one is when standing still (about 750rpm), and one when rolling (about 800-850rpm). Lowering the first may or may not cause vibrations, but lowering the secong to 750 should be OK?
Old 06-18-2009, 02:53 PM   #7 (permalink)
Eco Dreamer
I should say my method is with drive by wire... no adjustments on the throttle.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
Disconnected Idle Air Control - for lower RPM after a cold start Lazarus EcoModding Central 19 04-15-2011 03:50 PM
2000 rpm taco General Efficiency Discussion 37 02-28-2009 05:11 PM
Ford Aveo computer change Rpm shift? wally DIY / How-to 5 07-27-2008 12:16 AM
