EcoModder.com
-   -   Adjusting the Nut behind the CR-V Wheel (https://ecomodder.com/forum/showthread.php/adjusting-nut-behind-cr-v-wheel-27286.html)
B440 10-17-2013 06:17 PM
I've learned quite a bit from driving the vehicle since it was new. In the beginning I had an interest in what was a newly designed engine; I was all excited to have VTEC power! But in reality, I had bought an economy VTEC engine. Oh well, I'm no Speed Racer and it turned out to be a blessing anyway.
For anyone out there trying to figure out how the K-series engine works;
VTEC kicks in at 2200rpm and opens the second intake valve. Under 2200, and only one intake valve is in operation. I have already tried to disable VTEC by removing the plug connected to the VTEC solenoid. It immediately throws a code when you go over 2200rpm :(
VTC (variable cam timing) on the intake valves is always operating depending upon several factors and probably something I'm not going to mess with.
The "boost" everyone feels around 4500rpm is usually mistaken for VTEC. It's actually the switchover point between the long intake and the short intake. Why would I ever get to 4500rpm...:turtle:
Those features apply to 02+ CR-Vs, Element, RSX base model, and the 03 Civic SI hatchback. Maybe there are others?
So the big secret to get good mpg's in the CR-V? Not a secret at all; Driving slow on the highway
http://i142.photobucket.com/albums/r...ps8e3350fb.jpg
My trip was a little over an hour each way heading to and from Wachusett Mountain. I hit 30 on the way up to Wachusett, but no pic. I understand that I didn't do A-B-A. Seemed like the longer I could drive between 55-58mph, the more my average mpg's would creep up. 30mpg appears to be the magic number most people are shooting for with the compact SUVs.
That average number was with an auto trans, roof racks installed, a small grille guard and tires at 35psi. I think I can do better with more tire pressure and aero mods, but I'll be searching for a new vehicle next year, so I think the aero mods are out. I'm mostly a "city" driver anyway.
One last thing I learned from reading here; My decel fuel cutoff (DFCO) appears to happen anytime the vehicle can coast the engine up past 2000rpm. Very cool! and I wouldn't have noticed it without you guys mentioning to check instant mpg's when they go to 9999 on the scangauge.
UltArc 10-17-2013 07:19 PM
Images of the grille guard when possible? I always imagined a brush guard (like a push bar, but extending more so upwards protecting the front end) would be great for a grille block- perfect at higher speeds, as air should flow around it, but would let your engine breathe- plus it seems easier to build.
Of course testing and driving would be needed to see if it actually works, but ABABA should show if it does or does not.
Welcome aboard!
B440 10-17-2013 08:10 PM
Hmm, not a bad idea. It's a Westin Safari bar and if I covered it, it would block most of the lower grille. But I bought it because it gave me a good place to mount lights that work with the high beams. It would probably work for your Escape too.
UltArc 10-17-2013 09:06 PM
Not my Escape, but I always appreciate suggestions- it belongs to the roommate. We are currently trying to get rid of it.
B440 10-17-2013 10:07 PM
Escape was one of the choices when I was looking for a new vehicle at the end of 2001. CR-V won for the value of what was offered for the price point, overall reliability, and mpgs. I knew that I would be commuting every day to college, and then work. 20,000+ miles a year for four years.
Miller88 10-18-2013 09:03 AM
So the bump you feel at 4000RPM is secondaries opening? I drove a friend's 2005 accord and there's a noticeably increase in power at 4K.
B440 10-18-2013 07:49 PM
The Accord may also have the same economy vtec engine.
This video shows the dual intake with rotary valve at the 6:00 minute mark.... that I will post in the next reply:)
B440 10-18-2013 07:50 PM
http://www.youtube.com/watch?v=9ywhX7BP1m8
This vid is of the K20 engine, which is just smaller displacement, but same technology as the K24.
lol. Whoever recorded (or re-recorded) this video, was playing solitaire while it was recording, and the sounds from the game have been blended into the video.
B440 10-18-2013 07:56 PM
The safari bar is identical to this one. And I have similar lights mounted.
http://www.carid.com/images/westin/g...35-0020-02.jpg
I just found a transmission oil line leak when I changed the oil the other day, so I need to fix it before I can do any fun stuff :(
sheepdog 44 10-18-2013 11:30 PM
Hey, i\'ve been to your area! Once a year late in summer dozens of honda insights from across new england conspire to drive REALLY SLOW through your town. I apologize if you happened to have been stuck behind me! :turtle:
