Adjusting vss pulse number for tire size
Tried searching and couldn't find anything. If my tires are 3.6% bigger should I just scale the vss pulse number for my car in the chart back 3.6%?
If your speed readings are 3.6% lower with then yes you'll want to lower your VSS pulses per mile down 3.6%
Best way to deal with the issue is to compare your odo with the distance marks.
For example you drive for 20 miles/km and you check your odo in comparision with your MPGuino, or any other device. Then you calibrate it to show the proper number for the traveled distance. |
What is the method for adjusting the pulse?
Vic Hickey's son, Jim, manufactured an "add-on" digital box for GM products that connected between the wheel sensor and ECM to provide digital "calibration" of speedometer readings.
