Old 04-09-2015, 05:51 PM   #1 (permalink)
Hatch - '86 Honda Civic DX
90 day: 50.81 mpg (US)
Sedan - '92 Honda Civic Lx
90 day: 59.43 mpg (US)
Adjusting vss pulse number for tire size
Tried searching and couldn't find anything. If my tires are 3.6% bigger should I just scale the vss pulse number for my car in the chart back 3.6%?
Old 04-09-2015, 05:59 PM   #2 (permalink)
97 Civic HX sedan VX trans - '98 Honda Civic LX + HX + VX
90 day: 41.9 mpg (US)
If your speed readings are 3.6% lower with then yes you'll want to lower your VSS pulses per mile down 3.6%
1998 LX with a full HX swap + VX transaxle.
Old 04-17-2015, 09:37 AM   #3 (permalink)
AndrzejM's Avatar
Berta - '97 BMW 318 tds Compact
90 day: 62.03 mpg (US)
Charlie - '07 Citroen C4 Grand Picasso Exclusive
90 day: 37.58 mpg (US)
Corsa - '05 Opel Corsa C
90 day: 53.22 mpg (US)
Mruczek - '03 Audi A2
90 day: 60.61 mpg (US)
Best way to deal with the issue is to compare your odo with the distance marks.
For example you drive for 20 miles/km and you check your odo in comparision with your MPGuino, or any other device. Then you calibrate it to show the proper number for the traveled distance.
Gerhard Plattner: "The best attitude is to consider fuel saving a kind of sport. Everybody who has enough money for a strong car, can drive fast and hit the pedal. But saving fuel requires concentration, self-control and cleverness. It's a challenge with the nice effect of saving you money that you can use for other more important things."
Old 09-02-2015, 02:03 AM   #4 (permalink)
Donahue's Avatar
White Lightning - '04 Honda Civic HX
90 day: 40.5 mpg (US)
What is the method for adjusting the pulse?
Old 09-07-2015, 08:23 AM   #5 (permalink)
Mpguino calibration - EcoModder
Old 09-07-2015, 03:32 PM   #6 (permalink)
...beats walking...
Vic Hickey's son, Jim, manufactured an "add-on" digital box for GM products that connected between the wheel sensor and ECM to provide digital "calibration" of speedometer readings.
