Old 07-23-2009, 11:47 AM   #1 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
Air Dam vs Bumper mod
would i be better off installing an air dam or extending the front bumper down and forward so that the air goes up and over instead of out the side? I think if i used the air dam i would get more lift at higher speeds.
http://file.kbb.com/kbb/vehicleimage...sol88ls961.jpg
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 07-23-2009, 11:51 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
Extending the bumper would be best, but of course, more difficult.
Old 07-23-2009, 11:53 AM   #3 (permalink)
Team Pontiac
Any ideas for how to extend the bumper? nt
1991 F-250:
Old 07-23-2009, 02:58 PM   #4 (permalink)
micondie's Avatar
moby van - '03 Dodge Caravan SE
90 day: 19.74 mpg (US)
I would suggest an upper grille block with an air dam to direct more air into the opening below the bumper. It has been my experience that an air dam will reduce front end lift because it reduces air flow under the car.
Old 07-23-2009, 03:44 PM   #5 (permalink)
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
There are other considerations as well. An air dam could be closer to the centerline of the front wheels therefore be a little lower and a little less vulnerable to damage at driveway approaches, etc. An air dam even near the front axle line will decrease lift at freeway speeds from the stock set-up. Extending an air dam from the front of the bumper will decrease lift even more and be more slippery overall but vulnerability is a consideration.
Old 07-23-2009, 04:31 PM   #6 (permalink)
micondie's Avatar
I agree that driveway vulnerability is an important consideration. My 93 Trans Am's air dam is well under the nose and so low that I can't get a floor jack under it but it has never hit a driveway.
Old 07-24-2009, 10:25 PM   #7 (permalink)
...beats walking...
...to CONTINUE this line of thinking--when there's nothing there now, which is more beneficial? (A) a BIG air-dam or (B) a small air-dam like the OEM's use?
...any "ratio" of their true FE effectiveness?
...I know which is easier to buy and install: what's already been made and is easily bought at a junk yard!
Old 12-14-2009, 09:54 PM   #8 (permalink)
I definitely agree with this idea. However, extending the bumper would be a complicated job. But I want to try it real soon..
Old 12-14-2009, 10:07 PM   #9 (permalink)
How are you going to extend the bumper? With an air dam?
Old 12-16-2009, 02:38 AM   #10 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
I do not know what the car has under the plastic, but the same year Bonneville had an extra plastic 'spoiler' that mounted about a foot back from the leading edge. Since the cars are identical underneath the sheet metal, I bet you could find one and use stock plastic clips to hold it in place.
Comparing Warm Air Intakes (WAI) & Cold Air Intakes (CAI) toomuch EcoModding Central 27 11-20-2022 04:24 PM
Effects Of Air Dam (Ford F350 pickup) Big Dave Aerodynamics 59 05-06-2012 01:32 PM
My Geo Metro Air Dam Mod Hacksaw EcoModding Central 20 01-20-2010 09:32 PM
Cannibalize a 97' bumper for an air dam FunkSkunk Aerodynamics 10 09-10-2008 12:35 AM
Moving air intake into the engine compartment? pasadena_commut Aerodynamics 5 07-25-2008 03:24 PM
