10-08-2014, 10:07 PM
Does Ferrari 599 GTB Fiorano air ducting flying buttresses reduce drag?
According to Ferrari they create downforce without ugly wings.
Unlike conventional buttresses where the rear window is short, flat and vertical in the 599 GTB the rear window is long, inclined and curved.
Also unlike conventional buttresses they are open so they redirect air from the sides to the area behind the rear window, usually a negative pressure zone.
I think that by filling in the negative pressure zone they also reduced drag, Don't you think?
BTW such flying buttresses were used on the Honda/Acura new NSX prototype
10-09-2014, 01:12 PM
Could it be that these 'things' do not provide active downforce, but are there to make the air going along the side of the vehicle to go over the rear spoiler? Thus creating more downforce?
10-09-2014, 02:43 PM
I think they get rid of trailing vortices by moving air from the sides inward. The rear window is clearly too steep. Higher pressure in the back = more downforce. I'm sure the particular shape they used does something.
The Following 2 Users Say Thank You to serialk11r For This Useful Post:
10-09-2014, 06:22 PM
Ultimate Fail
I have no idea if they do much. I deleted one of them and ran a CFD simulation in an amateur program.
I looks as if there is a slight difference in the flow between them. By the way, the deleted side is on the drivers side ( left side of the car )
The Following 3 Users Say Thank You to Cd For This Useful Post:
10-10-2014, 04:29 AM
Ultimate Fail
I remember seeing these buttresses way back in 1993 on the Dodge 'Stealth' - though not as pronounced :
The Following User Says Thank You to Cd For This Useful Post:
10-10-2014, 01:01 PM
Ferrari does that sort of thing.
But then, Volkswagen has been know to do so as well:
10-10-2014, 01:22 PM
Renault Eolab Concept does it too.
I would wager that it's a compromise to get slightly lower drag on a less-than-ideal shape such as a notchback/coupe (Ferrari, Acura) or hatch (Eolab). You'll note that all-out aero cars such as the VW XL-1 don't have them.
The Following User Says Thank You to Sven7 For This Useful Post:
10-10-2014, 04:12 PM
drag
I don't know the answer.The C-pillar winglets on the 599 race car helped with rear lift with no drag penalty.Their 'suctioned' diffuser DID reduce drag.
On the Fiorano,the aspirated C-pillars may accomplish the same thing as the race car.Not really a drag reduction per se,just not a drag penalty.
PS the development of the winglets required hundreds of hours of trial and error in the wind tunnel.At 200-hours,that might be $400,000 at Pininfarina.
Reason: add PS
10-10-2014, 05:38 PM
#9 (permalink)
downforce
This was the premise of the 599 race car winglets,so it's extremely plausible that this is what they're up to.
10-15-2014, 06:48 PM
#10 (permalink)
Wow that's sooo amazing!
What CFD program is it? Where did you get it? How much does it cost?
BTW it looks like the buttresses help reduce the trailing dead area somewhat. Something like boat-tailing.
