EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Aerocap Thesis from 2009 (https://ecomodder.com/forum/showthread.php/aerocap-thesis-2009-a-15867.html)
bondo 01-21-2011 10:11 PM
Found another Engineering students Thesis on aerocaps I thought you guys might like to review.
There are some nice CFD graphics and a curved Aerocap was found to reduce the Cd the most. The fuel efficiency gain comes out to about 1 mpg in the calculations derived from the students CFD simulations.
I have experienced a higher percentage of fuel efficiency gain at around 3 mpg or 15% at sustained freeway speeds. Round.boater has seen a 15% increase also in the fuel efficiency of his truck since running an Aerolid, which he has recorded in his fuel log here on ecomodder.
round.boaters fuel log
http://ecomodder.com/forum/em-fuel-l...vehicleid=2565
In the last paragraph of the thesis, on future work, the student states a need to test an aerocap on a truck in the real world along with other aerodynamic devices.
Link
http://csus-dspace.calstate.edu/xmlu...pdf?sequence=1
Bondo
gone-ot 01-21-2011 10:39 PM
...nice to read about the 3" and 6" height front air dams too!
bondo 01-21-2011 10:42 PM
Yes it is.
I also like that different angles of the aerocaps were simulated. 12 degrees looks to be the best.
t vago 01-21-2011 10:43 PM
Dang me... My cap was indeed too aggressive. I had a 20 degree downangle. The coefficient of lift for 18.77 degrees increased by 63% over the baseline, in that paper. No wonder my aerocap flew! :D
Thanks!
bondo 01-21-2011 11:00 PM
Yeah t vago, lift is good for aircraft, bad for aerocaps.
The wind tunnel tests I did on my Aerolid in the A2 wind tunnel in North Carolina showed a significant increase in lift too. My lid is around a 12 degree slope. The students thesis shows a reduction in lift, at 12 degrees, which does contradict the data derived from test on my lid in the A2 wind trunnel.
redneck 01-22-2011 06:18 AM
Would adding tailplates lower the cd on the 3D aerocap?
t vago 01-22-2011 08:54 AM
I can definitely tell you with 100% certainty, that the answer to your question is a firm and definite maybe.
d0sitmatr 01-22-2011 11:20 AM
excellent read !
although I did notice here was not much variation between a standard aerocap @ 10 vs @ 12. however, the angled cap did provide a much greater difference over both straight 10/12.
going by that study, the best gains would come from a front air dam @ 6" coupled with the curved (angled) aerocap.
which also makes me feel much better since that was the direction I was going to take with my Ranger prior to trading it :)
aerohead 01-22-2011 04:07 PM
angles
I sure wish we could get away from 'angles'.Angles don't occur in high-performance structures,only compound curvature.
One can only discuss a particular angle,tangent to the body curvature,at any particular point,not some general area of the structure.
The folks did a lot of work.And the values are appropriate for their model,nothing else.They've essentially re-discovered Paul Jaray's work of 1922.
One would be warned if they believed any fast and hard rules would apply to these results when extrapolated out onto the general pickup truck population.
Sure,compound structures are the most complicated forms,most difficult to create tooling for,most expensive.But if you want the best quality fluid flow over a structure,you're hard pressed to beat them.
And if you ever intend to have all available kinetic energy transformed back to static pressure,and achieve lowest drag,you're pretty much locked in to using these forms.
Anywhere,except the automotive industry,will you find anything but these complex forms being used to eek out every bit of available energy when moving structures though fluids,be they gases or liquids.
Okay,rant over.Thanks Brett.
slowmover 01-22-2011 07:37 PM
A good read, all the way through.
