Old 10-21-2010, 06:43 AM   #1 (permalink)
inflatable boattail retraction
Inflating the boattail is easy, taking it back is the harder part. If you have any other ideas please post them.
I would love a boatail with shape memory alloy mesh in the fabric that was computer controlled so it could do origami or balloon animals but i dont think thats going to happen for a while.
A really popular option is the boatail thats only air supported and some how folds up and then rolls back in completely neatly and also compactly. Im not really sure how to do that kind. High air pressure lots of various springs inside?
Heres a few others.
1. Hinged bottom panels that fold up. A rope spirals around the inside of the tail several times and connect to the far end. The rope spiral pulls the fabric inward and the bottom up.
2. Stacked series of ribs inside the tail that extend back on a lazy tongs type of mechanism. Between the ribs are rods that fold inwards as it retracts so the tail folds up like a big accordion.
3. Similar with ribs extending on lazytongs but instead of folding parts the even numbered ribs rotate and the odd numbered ribs dont. The excess fabric is twisted between the ribs as it retracts.
edit:
4. Hinged flat bottom panels with hinged ribs attached to them with folding rods between the ribs. The ribs would fold down and then the panels up.
Old 10-21-2010, 07:20 AM   #2 (permalink)
Before someone recommends the tail works exactly like these.
compare the diameter of the tube to the wider width of the roll and the diameter of the roll. If the tube was the back end of the vehicle the boatail wouldnt retract small enough in length and would stick way too far out the sides.
Old 10-21-2010, 07:42 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
No 12v dc air sucker idea?
Old 10-21-2010, 07:57 AM   #4 (permalink)
That could be used for many of those ideas. Air sucker used alone the tail would flatten and then drag and flap all over the place.
Old 12-27-2011, 01:29 PM   #5 (permalink)
Heres a few others.
edit:
Well check this idea out.
Completely automated. Driver does nothing.
Inflatable boattail bennelson Aerodynamics 77 06-24-2015 02:03 AM
Boattail on a Prius ENERGYprof Hybrids 29 06-04-2013 12:38 PM
Another civic hatchback boattail... bikeracer EcoModding Central 2 10-02-2009 09:46 PM
Inflatable boat-tail - concept stage... hummingbird EcoModding Central 10 03-20-2009 02:33 PM
Gotta rebuild the boattail basjoos EcoModding Central 47 11-22-2008 11:11 AM
