Aerodynamic pressure testing video
Two quibbles:
I'll take one out of two, obviously. :)
I can't see being sucked forward by the edge of the hood. I suspect it's negligible. |
Look at the pressures, multiply by the areas, use the triangle of forces to calculate the horizontal component. Certainly not negligible. |
So the Beetle's bluff forebody is a liability?
https://i.postimg.cc/VLBz8XTP/B-4.png Jaguar XK Blue = thrust Red = drag Green = neither lift nor drag Now we can't see the stagnation zone at the front of the car, nor the base area in the wake at the back (and both will be red), but you can see why car makers try to optimise front curves to give thrust. |
Are they factoring thrust and drag out from the normal?
