Aerodynamic work trailer.
When we sold the Saturn vue that left us in a bit of a pickle for carrying things.
As the new car would be my wife's she had most of the day in it. I wanted a wagon, but I was informed that is what old people drive. Interestingly enough, the Jetta can fit 3 adults and a 6' ladder. The problem is we sometimes need 2 8'ladders and a 6' This car is NOT getting a roof rack, period. The other option is to drive the truck (<20mpg) This will also replace our camping wood/dirty/wet stuff trailer.(currently a 4x6 box) So I've spent some time designing a tapered trailer for work. It needs to be 100" long for the ladders and 32" tall in the front and 62" wide. Here is the big question, I expect to use plan taper. What benefit/loss will there be if I make the top/lid flat vs tapered? Losses: True kamm back air flow Benefits: Flat surface to work on. |
How much flat surface do you need? If it only needs to be flat but being level to the ground isn't an issue, then you can simply have it running at a constant angle from bow to stern, no problem.
If you want something close to level to the ground but also don't need a very large work surface, then you could achieve your goal with a somewhat faster angle near the bow, but it flattens as you approach the rear until the final 2-3 feet are more or less level. Tapering the sides in toward the rear is a no-brainer in my book. And the closer the bow is to the tow vehicle, the better. Aerohead has posted a lot of good info on aeromodding trailers for maximum slipperiness. Finally, if this is an option, why not build in either a removable work surface or bench, or include a large pullout that will both make unloading the trailer easier and also be already level (more or less) to the ground? That can be pricey and adds to the curb weight of the trailer, but I think you would get a lot of it back in convenience and the freedom to optimize your trailer's aerodynamics would more than compensate for the weight and encumbrance. |
Yeah, I didn't want the work of a teardrop so I was planning on a straight sloping parallelogram.
I know this doesnt meet your requirements
but I saw it on the local CL recently thought it would look good behind my silver Prius for camping 2007 Thule Utility Trailer Quote:
http://i.imgur.com/1ZPfP.jpg
The top can be parallel to the ground, that way you won't loose interior space. Notice these flat-top fenders; if they were doubled with a piano hinge on the outer edge, they could fold out into work-benches. Why the 32x62" dimensions? Will you taper all the way to a point or truncate to a flat back? Ignore that this is a tear-drop. The edges [to scale] are 4', 3' and 5' with a 2' wide rear, based on a 4x12' plywood sheet. http://ecomodder.com/forum/member-fr...17-trdrp1a.jpg The axles are pushed back to keep them within max width. The next iteration [were there one] would have the edges 4', 4' and 4' with the axle[s] in the middle section in wheelwells cut into a 5' wide floor. Here's the frame and floor laid out over a teardrop template: http://ecomodder.com/forum/member-fr...-trdrp-frm.jpg What do you propose for materials? Plymetal Swingdoor panels are plywood skinned with aluminum Quote:
trailer top
here's a link to an image of the 1917 Zeppelin-Staaken R VI 'giant-bomber'.
It's roof has a bit more side radii which you'd like in crosswind http://www.internetmodeler.com/2006/...Staaken-01.jpg |
Couple of answers :
A ladder stood on edge is 29" so 32" seems about right. A sheet of ply wood is 48", the taper cuts a 14" piece off, that turned around makes 62" W. |
top angle penalty
here's a drag table which shows some loss when the roofline doesn't descend
http://i1271.photobucket.com/albums/...ead2/Scan4.jpg |
I guess I'd need a picture. You're only tapering one side? :confused:
Starting with a 5x10' sheet, there'd be some waste but you'd have a one piece floor. |
Freebeard,
I'm tapering both sides equally from 62" to 34". My big dilemma is to leave the top flat or taper it as well. |
