Old 05-22-2012, 07:00 PM   #1 (permalink)
Input needed XTerra (Gas Piggy) & R-Pod
I have a (paid for)2004 Xterra(gas piggy) and bought a R-Pod 171 because it was one of the few my Piggy (Xterra) could pull comfortably. The R-Pod looks all aero but come to find out it's shape makes it act like there is a parachute in the back.
I'm looking for input on mods that would help. I'm going to do some of the starter stuff, take off the luggage rack, make some flat covors for the headlight buckets etc.. But I am thinking of a air deflector on the back of the piggy and and end cap on the back of the R-Pod.
I'd love to hear any and all (constructive :-) thoughts y'all might have about improvements. Thank you!!!
(First time using the Flow Illustrator. I'm going to take a pic of my rig the next time the R-Pod is hooked up. I put this siloutte together from web pictures so it might not be perfect.)
http://sdrv.ms/KG5om8
http://sdrv.ms/KG5utO
http://sdrv.ms/KG5A4I
http://sdrv.ms/KG5HgS
http://sdrv.ms/J8ReEU
Old 05-23-2012, 07:42 AM   #2 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Can you put a stake in the ground? What kind of gas mileage are you getting? How does towing FE compare to your normal city and highway numbers? That might give us some idea how much headroom might be possible.
Recreation Engineer
Old 05-23-2012, 10:55 AM   #3 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
My wife had an Xterra for years. She refused to calculate gas mileage and I couldn't make myself drive it long enough to do it myself. But pulling a camper with a parachute on it could only have helped.
I'm sorry I can't offer much more constructive than understanding your pain right now.
Transmission type Efficiency
Old 05-23-2012, 06:04 PM   #4 (permalink)
Piggy &
Will wait for photos.
Old 06-05-2012, 03:17 PM   #5 (permalink)
Engineer
Send a message via AIM to Axv129
XDotNet, I have a pathfinder and a R-pod 171 and I'm in your boat. I want to drastically improve the Cd of this rig. I followed your lead and have done extensive modeling in Flow Illustrator. Right now I'm finding that the higher pressure air under the rig is forcing the lower pressure air on the topside from following the structure. I'm thinking that an airdam under the RV would stop that. I'm also actually going to add a roof rack, bacause all the modeling is showing that I need a boost to get the air passing over the RV.
