Aeromodding a 2021 Freightliner Cascadia
4 Attachment(s)
6 weeks ago a signed a lease to drive a truck pulling reefer trailers cross country. They pay a certain number per load for fuel, it I use more, it comes out of the pay line. If I use less it goes in my pocket
So here we are. I can't do too much crazy stuff but considering the 2023 is available with aerox package a la carte, I may buy some factory pieces, I may build my own. So far I've been eyeballing the bumper extension/airdam but they seem susceptible to damage, wheel well filler trim pieces and my 10" side skirt extensions. So far, I've found stated numbers of .25% efficiency increase with commercially available wheel covers for the rear. If my truck seems to average 8 mpg loaded, that doesn't seem enough for what they cost. Diy in process Sorry I haven't been updating, although I have been at it. See updated photos. My latest idea is to build a quick attach trailer tail. That's what the sketch with the measurements is for. I believe most of the trailers will have hinges in the same place so I'm considering a mount to them. I thought about wheel covers for them as well but I'm sure I would forget them and the first time I have to drive back to get them it would negate any savings I may have from utilizing them. |
Man, I'd get pretty crazy AB testing if I got to pocket the fuel savings.
Guess you won't be going in this direction https://q4j8c2c6wsreh73d2o6m0w1a-wpe...Wheels-For.jpg Welcome to the forum. |
Welcome.
Do you know how to search the forum? It goes pretty deep. Do you control the trailer, or are they rotated out? Here's something that relates to your use case: https://ecomodder.com/forum/member-f...dynamics-c.jpg |
Red, unfortunately I'm not a scientist, I'm not cool enough because I have a plastic bumper and a robot shifting gears for me
Free beard I've been lurking for 8-10 years. I'm pretty familiar with site functions thanks. Unfortunately I can have the same trailer for a few days or even weeks but the hope is to drop and hook at every stop. I have a sliding fifth wheel which I was hoping to slide all the way forward but weights do not permit. |
2 Attachment(s)
All of the trailers have skirts and super single tires, some have 4 sided trailer tails, some have two sides but they're skirt always broken. The new trailers seem to have a two inch treatment along the lower middle of the door and a5 inch spoiler along the top and sides. I'll try to get some photos
Got it. Lurkers are important.
I don't care enough to search but there were wheel disks that expand like a crochet hoop to grip the wheel. Maybe they could be moved from one trailer to the next. |
Probably an old hat to you, but Vekke designed smooth hubcaps for trucks/trailers some 11 years ago.
this is his thread: https://ecomodder.com/forum/showthre...cks-16478.html and these YouTube videos seem to be most informative: https://m.youtube.com/watch?v=nfbCXSkLiKA https://m.youtube.com/watch?v=lqD3pXVmnQc Covers are made of 3mm ABS sheet, iirc. The design is pretty straighforward, so you should be able to duplicate it, unless you are hopeless with jigsaw. I would try it for sure, if I were in youe shoes. smooth hubcaps are how much? 3 %? |
Not the same one [IIRC] but just as good. :thumbup:
A good tire pressure gauge and a long enough air hose to reach the trailer wheels. Properly inflated tires make a big difference when hauling heavy. Oh, and a scangauge. :turtle: > . |
Seifrob, thank you for the link and videos. Looks like I'm going to buy a jig saw.
Redneck, I have a gauge. I need to buy a hose and adapter. Thanks for the ideas folks, keep them coming. I'm looking at extending the side fairings and an air Dam/splitter. |
