Old 10-07-2011, 10:54 PM   #1 (permalink)
redyaris - '07 Toyota Yaris
90 day: 45.54 mpg (US)
Gray - '07 Suzuki GS500 F
Motorcycle
90 day: 70.4 mpg (US)
streamliner1 - '83 Honda VT500 streamliner
Motorcycle
90 day: 75.63 mpg (US)
White Whale - '12 Sprinter 2500 Cargo Van
90 day: 22.01 mpg (US)
Smaller Windshield Wipers
I resently disided to install a smaller windshield wiper I had in the van, because one was brocken. I installed the smaller one and then it occured to me, that if the windshhield area that is needed is clear, then there could be a aero benifit to smaller wipers. I have found wipers as small as 10". This is an easy fix for those unwilling to remove wipers entierly.
Old 10-07-2011, 10:58 PM   #2 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Mazda Protege DX
90 day: 46.42 mpg (US)
I went the other way. I removed the passanger wiper and got a 2 inch longer drivers wipper. The passanger wipper never got "tucked" under the hood lip so it was always in the air stream. The drivers wipper I can run on high and quick with the switch get it to stop under the hood lip so it is out of the air stream.
Old 10-07-2011, 11:07 PM   #3 (permalink)
Motorcycle
Motorcycle
My Yaris Wipers are exposed as are my Aerostar Van wipers, so until I get around to a wiper shield the smaller wipers may help and still clean the windshield.
Old 10-08-2011, 08:37 PM   #4 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
busypaws -
When my current set wears out I am going to copy you. I will keep the passenger wiper in the trunk, but it will be 2 inches smaller.
CarloSW2
American Solar Energy Society
Old 10-08-2011, 10:32 PM   #5 (permalink)
Motorcycle
Motorcycle
The Yaris has a 26" driver side wiper and a 13" passanger side wiper. What I plan to try is 13" wipers on both sides. which may be ok for a relativly dry climate, I guess I'll find out...
Old 10-10-2011, 12:28 PM   #6 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Pontiac Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
Be aware that the spring in the wiper arm is weighted for the OEM length wiper. Safety is a consideration on this mod.
1996 Pontiac Bonneville SE 3.8L V6
Old 10-10-2011, 11:11 PM   #7 (permalink)
I think wipers in the off position add virtually nothing to the drag. They sit in a high pressure pocket of air, that hardly moves at all, on most cars.
Put a maple seed or a small leaf in the pocket and drive for a while on a still day, and see if it blows out of there?
Old 10-12-2011, 10:54 PM   #8 (permalink)
Motorcycle
Motorcycle
Thanks neilB but what I will do instead is put some tufts in the area and see what gives.
