air conditioning aero drag and heat flux to radiator
* typically, the air conditioning condenser coil is placed upstream of the radiator. It's aerodynamic drag is present whether or not the system is operating, depending upon active thermal management of the cooling system, while at rest, under artificially-induced airflow, or dynamic pressure-induced flow.
-------------------------------------------------------------------------------------- * engine / motor cooling load, battery cooling load, and climate control heat rejection must all be handled by the cooling system. -------------------------------------------------------------------------------------- * climate control must satisfy full passenger metabolic heat flux, any engine compartment firewall conduction, non-glazed exterior surface heat conduction, and glazed surface, direct solar greenhouse effect and infrared radiation at full-sun, peak Summer heat, at Furnace Creek, Death Valley, California, USA ( typically 120-F ), at 'idle', parked, with all accessories 'ON,' to a specified thermostat setting. * electric forced-air power consumption must be part of the vehicle's energy accounting. |
Yes, but what's your point?
point
You're kidding, yes?
Yes, so what? Everyone knows all that, I would have thought. |
not sure
In your normal overly complex manner, you're simply stating what is obvious to anyone know knows anything at all about cars:
I guess it's only some kind of breakthrough if you'd never considered these aspects before. |
The extra drag caused by a condenser is tiny, and I haven't seen anywhere any manufacturer stating an increase in drag by opting for the air conditioning extra. I don't believe it is relevant or beneficial.
There is extra drag caused by the belt, the clutch, the weight of all the components too. And I think they have more of an impact, which is still tiny. Quote:
aerohead, if there is something important that we have all missed, and only you can see, let us know. And preferably, let us know in the first thread post. |
light bulb
If any passenger emits 300 Btu / hour, metabolic cooling load, and four no longer equals seven, then we finally have a context with which to compare a 911 Carrera to a Model S, cooling-wise. |
something
As has been pointed out, you haven't done so - and so telling us to re-read what you've written is not much help. |
