Old 12-05-2016, 11:53 PM   #1 (permalink)
Amelia Pond - '13 Honda CR-Z Base
03 Santa Fe Mooncap / Pizza tray Question?
So I have an 03 Hyundai Santa Fe, It has stock OEM 16 inch wheels as pictured below
I don't want to drill into the alloys. Based on the wheels in the image above. I was thinking of attaching the pan via a ziptie through two holes in the pan around each spoke as described in this diagram.
Would this work? Does anyone have a better idea?
Old 12-06-2016, 10:35 AM   #2 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I don't see why that wouldn't work. Consider drilling access holes for the valve stems; you can find rubber plugs on ebay to cover them.
UIUC Aerospace Engineering
www.amateuraerodynamics.com
The Following User Says Thank You to Vman455 For This Useful Post:
aerohead (12-10-2016)
Old 12-06-2016, 09:09 PM   #3 (permalink)
Maybe zip-tie/epoxy a plate between the ribs at you location and have a metal to metal connection, instead of the pizza tray sawing on your zip-ties?
Else you could just dimple the holes.
