Old 10-03-2010, 01:30 AM   #1 (permalink)
FalconFour's Avatar
LEAF - '11 Nissan LEAF
Differences between prebuilt MPGuino code & official code
edit: Um... well, I guess you can delete this. I'm having a lot of trouble with the disorganized nature of the MPGuino information online - in the (now "no longer maintained") forum post, website, and Wiki... the Wiki led me to the forum post which pointed to an outdated version of the MPGuino code (v0.75) which was apparently written before the 20MHz crystal was used, and I was in a headache-inducing position of figuring out the differences between the prebuilt MPGuino's code, and the official "trunk" code... now I find out there really is none, and I was just using an old version.
I think my first contribution to MPGuino can be reorganizing the data in the Wiki so information can be more easily found, and old info can be more easily removed or updated...
But above all, I'd really recommend going back and updating that "no longer maintained" post, since so many things are linking to it (such as every reference to MPGuino above)...
Old 10-03-2010, 04:14 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
original arduino version:
schematic: http://opengauge.googlecode.com/svn/...ino/wiring.GIF
code: http://opengauge.googlecode.com/svn/...no/mpguino.pde
hardware: 16mhz atmega168, pnp backlight driver
notes: versions of arduino newer than 0011 may not work, not being maintained as much time spent fixing what new versions of arduino break. Non-trivial application.
latest prebuilt version (hw 1.3, sw 0.86):
schematic: http://opengauge.googlecode.com/svn/...no/mpguino.png
code: http://opengauge.googlecode.com/svn/...no/mpguino.cpp
additions: metric, edge selectable inj trigger, floating decimal for bignum, various power supply and reliability improvements, no arduino dependencies.
hardware: 20mhz atmega328, npn backlight driver, stn (low current) LCD
Old 10-03-2010, 05:17 AM   #3 (permalink)
FalconFour's Avatar
Indeed, I'm now finding all the most recent info.
Already started hacking apart the code, slowly digesting all that's already been done (and if I may say, you're a hell of a great coder, if this is all what I think it is ).
Here's what I've got planned so far:
- Remaining miles on tank using existing "tank size" figure and using "tank MPG" and "tank gallons" (planned and implemented already, need to find a good "screen" for it)
- Editor for critical "tank" figures to recover from a power cycle (like the parameters editor, allows to enter/edit tank gallons, tank miles)
- Clock, if just for curiosity's sake (AM/PM kind of clock)
And already implemented:
- Added "improved font" from Wiki's "code hacks"
- Disabled/removed serial output, decreased "CPU usage" by about 10% even with new font
- Remove metric functions (I have no use for them personally, saves room for other changes)
And with about 15k of free Flash, that leaves plenty of room for the eventual ALDL reader
Old 10-26-2010, 03:16 PM   #4 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
you can also gain a lot of speed by changing the two instances of
delay2(5);
in LcdCommandWrite() and LcdDataWrite() with something like
delayMicroseconds2(43);
because if you display 16x2 so 32 characters on the screen, you are losing about 160ms every refresh, for nothing, as displaying 32 characters needs less than 1.5ms.
2013 Hyundai Sonata Hybrid
Old 11-10-2010, 03:37 AM   #5 (permalink)
Don't tease. ALDL would be awesome!!!
Old 11-10-2010, 03:38 AM   #6 (permalink)
Please edit the WIKI AND the forum thread. For a newbie I'm really confused which version I should use, and which is which.
It would be great if all were updated and synchonized.
Also can I use the most modern Arduino software 0.21 to program it now?
Official MPGuino preassembled now available dcb OpenGauge / MPGuino FE computer 445 04-19-2016 10:13 AM
Enhancements to MPGuino code -- bargraph display, etc. skelly OpenGauge / MPGuino FE computer 26 08-12-2013 10:41 PM
basic questions about prebuilt MPGuino usergone OpenGauge / MPGuino FE computer 12 06-11-2010 04:23 PM
Mpguino prebuilt, know what you are buying dcb OpenGauge / MPGuino FE computer 0 10-24-2009 04:27 PM
Help w/ mpguino space shuttle code please forgottenmindset OpenGauge / MPGuino FE computer 14 09-07-2008 03:17 PM
