air flow over Infiniti Q45 w/IMPUL body kit
On of our british members VIIO, :thumbup: has a software program that does the following:
(based on this photo) http://i678.photobucket.com/albums/v...G/IMG_2383.jpg Here's a model of the air velocity affecting your car at 55mph - red is slow (drag/turbulence) and green/blue is full speed air (low drag = good). http://i4.photobucket.com/albums/y14...5-velocity.jpg This model is of the pressure affecting the car, as you might expect, the air pressure is mainly on the front of the car and creates a bow wave similar to a boat in water. Areas in blue are low pressure and will actually be providing downforce to your car - for example underneath your front airdam lip. http://i4.photobucket.com/albums/y14...5-pressure.jpg Hope this helps! __________________ Viio Amateur SolidWorks Flow Simulator We are going to adjust the rear to relect the rear spoilerhttp://i678.photobucket.com/albums/v...G/IMG_2384.jpg |
