Old 10-28-2016, 06:34 PM   #1 (permalink)
thrashbox
95 Tercel twin cam 1.5
Hello all. I have been trying to remove the stumble and subsequent continuous misfire. I have to let off the gas to return to running on all 4 again. runs great when cold. New idle valve and new tps I adjusted to .6 volts. I appreciate any time you have to help and thank you all. Tip your waitress. Dave
Old 10-28-2016, 11:58 PM   #2 (permalink)
90 day: 40.51 mpg (US)
Possible fuel pump, or filter?
buzzbox (11-18-2016)
Old 10-29-2016, 01:35 PM   #3 (permalink)
Cinco The Miata - '90 Mazda Miata
Team Mazda
Sports Cars
90 day: 36.13 mpg (US)
Oscar Wilde - '02 Honda Metropolitan
Motorcycle
90 day: 94.9 mpg (US)
Wrong temperature spark plugs?
The Following User Says Thank You to AntiochOG For This Useful Post:
Old 11-03-2016, 06:12 PM   #4 (permalink)
Tercel - '92 Toyota Tercel Base with 5EFE swap
I just finished a 5EFE swap into my '92 Tercel and had a similar issue initially. It was almost un-drivable at first, but after closing the plug gap down it cleared right up, and then with a fresh set of plugs it ran like a top.
What have you done so far?
The Following User Says Thank You to WaterPog For This Useful Post:
