Old 10-13-2013, 06:01 PM   #1 (permalink)
Auto to manual conversion question (d15z1 civic)
So from my previous threads I have now decided to go with a z1. I got everything from a 5spd, everything except the pedals, for 125$. Now, I have a couple questions that maybe you guys can help with. With the pedal conversion is it possible just using the 5sp break and clutch, or do I need the gas also? With wiring the break lights, it says in another diy that I should run the yellow and green wire into the center console plug, but which yellow and green? The 5spd trans only has one plug and both wires are green. Also on the clutch, there are two sensors, is the bottom a must to wire into the center console? and whats its purpose? Any help on this would be greatly appreciated, and once this is cleared up I will start my conversion thread.....thanks.
These green wires, where are they from? I assume they are for reverse lights, but where do I get them from? Also it would help to say I have a d15z1 5spd engine harness complete, in case that changes anything.
