Ambulance Aero
Hello All.
Question: Do you think the larger cab on a medium duty ambulance will give better aero than a light duty ambulance? Below is Freightliner M2 106 next to a Ram 4500 with the same size box. I know box trucks and Class C RVs have horrible aerodynamic due to the large flat profile on the front of the box. The MD ambulances have much less of the box exposed and I'm thinking that might be why I'm seeing similar mileage claims for medium duty ambulances as for light duty ones. https://i.pinimg.com/originals/81/52...aaa82fd3a4.jpg The back-story: As some may know my wife and I are looking to travel full time in about 2 years. Our current campervan is too small and we are looking for something bigger. At first I was looking at high roof Transits or a box truck. Then I got turned on to ambulances which are basically a box truck with a MUCH better built box on them. All aluminum construction with lots of lockable storage already built in. The only down side is most are van based and after 2 decades of helping my father wrench on Econoline vans I have no desire to own a Type III ambulance built on a cutaway van chassis. There are Type I ambulances built on truck chassis. Those have some benefits like easy suspension upgrades and more room to work under the hood. (Although if a turbo goes out the cab has to come off!) The big downside is that Type I trucks built on a F250 - F450 chassis rarely have a walk-through to the cab. That is a must have for us Then I starting thinking about Medium Duty Ambulances. At first I though they would be WAY to big but the box is the same size. The major difference is the size of the cab.... |
Holding a straight edge up to the screen suggest that the hood height is the same but the box on the left is taller. Does it have a higher floor level? I'd guess the medium duty has the advantage aero-wise.
Not having a walk-through sounds like a solvable problem. |
The finnish way to build them:
https://www.profilevehicles.com/en/s...rez-ambulance/ |
Top of the frame rails to the top of the cab: 47 inches - F450 58 inches - E450 68 inches - M2 106 I suspect this is why most pickup based ambulances do not have a walk-though. It would be more like a crawl through. Quote:
http://www.hatzalahchicago.org/wp-co...ruction-05.jpg Quote:
https://www.fedextrucksforsale.com/w...n-for-sale.jpg |
The walkthrough is a local option. Class C camper cabs have it. Why not just use a box truck? Them 16 ft Isuzu things get flogged to death and keep on trucking.
https://personalspaceministorage.com...12ft-truck.jpg A typical box truck has a flimsy wooden box on a flatbed covered with either fiberglass or aluminum. They are prone to leaks and rotting of the wooden core. I also doubt most would survive long if subjected to a steady diet of rough forest service roads. Most box trucks are also made to back up to shipping dock 48 inches off the ground so the box is too high. (Bad for Aero, bad for getting in and out of the box, bad for overhead clearance) Ambulance boxes must be crash tested and certified. They are made of welded aluminum tubing and some have the seams of the exterior aluminum welded. Most are insulated from the factor. They also come with a bunch of external storage compartments already made that are lockable and watertight. Ambulances have:
Then there is rust or lack of rust. A M2 ambulance has an aluminum cab with an aluminum box. Quote:
Back to aerodynamics. I would likely do an air deflector on the top of the cab (factory option so easier to find / install than some custom fabrication) Medium Duty side profile https://d2uhsaoc6ysewq.cloudfront.ne...6-17956970.jpg I would likely do an air deflector on the top of the cab (factory option so easier to find / install than some custom fabrication) Pickup side profile https://arrowambulances.com/media/IMG_6134-900x675.jpg |
What's the difference in rated fuel economy?
If the medium duty has a passthrough cab, then there's no comparison. They're both a wreck, aerodynamically, but a nicely curved deflector looks easier on the medium duty cab. Also less side overhang
Passthrough cab over all. |
I mean, it's the squared off rear-end that's the biggest problem; and probably not easily solvable while maintaining the ease of access.
I’d be happy with 15 mpg at 60 to 65 mph. That is more for personal satisfaction than economics. At 20K miles a year and $3.50 a gallon the difference between 15 mpg and 10 mpg is $2333 per year or $195 a month. Quote:
https://www.kloompy.com/oc-content/u...128/188504.jpg Some friends of ours have an RV like this with the Ford V10 and get 6 mpg at 60 mph Quote:
https://base.imgix.net/files/base/eb...op&h=432&w=768 The back doors won’t be used to get in and out of the vehicle. Ambulances have a side access door on the right side. I plan to have a bed across the back of the vehicle with a “garage” storage below. I jumped in a M2 106 at lunch and the sightlines are night and day different compared to a full-size truck. Nice roomy cab too. That is another check in favor of a Medium Duty. |
I spotted a '08-'09 Dodge Ram 2500 with a coachbuilt motorhome body this Sunday, and its proportions reminded me of an ambulance, even though it had a sleeper over the cab that smoothed its frontal area a little. Maybe getting a light truck instead of medium-duty can be beneficial, as the lower cabin may keep room to add either more storage or sleeping area without increasing the overall height.
An inflated half-round on the vertical edges would help as much as the deflector. Assuming they run all the way to the top.
So in addition to flaps there are little fairings like Michelin uses: https://aecbmesvcm.cloudimg.io/v7/ht...c-feature3.jpg I also won't have a smooth top to the ambulance. I'm planning about 1400 watts of solar and at least one powered vent. and also little turning vanes like Rockettail https://h7f7z2r7.stackpathcdn.com/si...?itok=v2QAJuEI The problem (for me) is that they are generally tested as a complete kit with underskirts, wheel covers, and other aero aids. I also won't have a smooth top to the ambulance. I'm planning about 1400 watts of solar and at least one powered vent. |
Thanks for the reasoning on why not a truck. Low access height does mean you will have wheel arches to contend with.
You need to check on jurisdictions, our ambulances sometimes have the side door, but always have the pass through. Everyone specs out their needs differently. 6mpg isn't bad for something driven with two pedal conditions: full on and full off. I suspect they would get 12-13 driven sanely which is what I got dragging my big boxy unaerodynamic toy hauler. Solar on top shouldnt add to much friction drag as compaired to a/c and emergency access mandates. |
better
From what Hucho shared in his chapter on commercial vehicles, and NASA's reporting, the Daimler-Benz Freightliner would have the advantage.
Daimler's design blows a bigger hole for the box to trail behind, and that added width and height better takes more of the leading edge hit, than the horrible face of the box. Ideally, the cab would be just as big as the box, as with Tesla's Semi/ NASA's semi, most current Class-8 rigs operating at a profit. It's the difference between Cd 0.89 and Cd 0.41. |
The Finnish way
air deflector
For sure!
If you could seal as much of the gap between cab and box, that would also show. ( delta-Cd 0.016 on my pickup ) Also, extend the box sides down even with the bottom elevation of the running boards / step. Wheel arches? |
1 Attachment(s)
Attachment 31051 Some ambulance layouts work better than others for camper conversions. The ambulance above isn’t ideal due to the tall vertical outside cabinet with the yellow X. That would need to come out to put a bed across the back. Quote:
https://i.imgur.com/teRbDK4.jpeg Quote:
You last example has the overcab deflector already but no opportunity on the edges. It would need the doors reframed or padded out. |
http://3rd-st.com/Darpa/rough_road2.jpg M2 ambulances come standard with 19.5 inch wheels. I'll have to see what is required to fit 22.5 inch wheels. Nothing extreme like this truck https://www.ambunet.com/wp-content/u...river-Side.jpg |
That example would need an ogive curve that follows the sweep of the opening door and then goes convex at 4% of the overall width.
Treat yourself to this
https://i.insider.com/5eb18814144192...36&format=jpeg Seriously though, I'm getting excited for your retirement plans. Swing by and visit Silverton when you embark and I'll send some beers along for your travels. |
a look at Cd 0.38
4 Attachment(s)
https://ecomodder.com/forum/member-a...here-money.jpghttps://ecomodder.com/forum/member-a...nt-attacks.jpghttps://ecomodder.com/forum/member-a...-windkanal.jpghere's a link to a dated Mitsubishi box truck worth looking at. Some box truck at the time were near Cd 0.90.
https://ecomodder.com/forum/member-a...aero-truck.jpg You can get away with murder at the front, but gaps are expensive, and transitions to the 'roof' need to be 'tuned'. You'll notice flow separation on the roof of the trailer van. On the way to see the Dynaxion Car, at Harrah's Auto Museum, Reno, Nevada, I snapped this shot of leading-edge 2-D flow separation on a bridge abutment under a bridge over the Truckee River. It offers a clue as to aerodynamic challenges with 'hard' edges. Finally, Hucho's iconic image of a squareback wake, which you'll never find used in nature. |
https://ecomodder.com/forum/attachme...1&d=1627058664
We'll cheap out on the formwork for the abutment, but people can see the brackets so we'll make them Art Deco Streamlined. |
Which is part of the problem. Plenty of things that "look" like they should be aerodynamic aren't actually. For example you may think extending side fairings on a truck back to the rear wheels would be better than a short fairing. However, that isn't always the case. The early full wheel to wheel fairing on a Cascadia is less aerodynamic than the later model short fairing that stops even with the cab extenders. https://orion.soarr.com/photos/16019...cascadia.3.jpg https://www.imanpro.net/pub/co/dot/p...20200316104950 |
1 Attachment(s)
Well - I have an ambulance.
2011 Chevy Express 4500 with the 6.6L Duramax and 6 speed auto. 110K miles / 4200 hours Now I just have to get it home. (It is in North Carolina) https://ecomodder.com/forum/attachme...3&d=1647478971 |
What's the plan?
Sure that box would be a good base for a tiny house conversion. I guess you could take some good inspiration from those people who convert prefabricated sheds into tiny houses.
I've got paternity leave pending...
If it doesn't get picked up I'll be back in NC in a month and will drive it back. I still have a week of vacation to burn by the end of April. That is just a poor use of vacation days |
Buck a mile sounds right based on all the vehicles I had to arrange but never with a freight company, it was all vehicle transport on an auto carrier. Gonna suck up 1/2 or more of a flatbed, lowboy cross country, I dunno. Any prices on specialized auto transport and how flexible are you on delivery city like perhaps SACTO
(This ambulance came out of California). |
[the movie Vanishing Point]
I suppose it would be obvious to have it delivered out of CALI then?
I am very hesitant to buy a truck like this sight-unseen. I didn't expect to buy this truck due to the location but it was in too good of shape to pass up. Not only is this truck immaculate outside - it is fantastic underneath as well. Looking at it up on a lift this is the most rust free vehicle I've seen. No fluid leaks either. The dealer also runs a HD truck shop and it has all new fluids, filters, brakes, and 6 new tires. It is also the lowest hour ambulance I've found in my ~ 1 year search. Most low mile ambulances have very high hours from the crews idling them all shift. It is crazy to see how many ambulances with 200K miles or less that are advertised with replacement engines. EDIT: It was also easy to insure. One thing that always pops up on campervan forums is how hard it is to get insurance on an ambulance insurance companies refuse to write policies for them. The general advise is to insure convert the title to an RV. That is not the case. I called Progressive, told them what I had, they said I couldn't get a personal policy but their commercial group would be happy to insure it, they transferred me and it took about 15 minutes. |
I am aware of where it is currently, I completely understand the complexity of getting it to where you are, in addition to purchasing it without a good level of trust. One van I had paid transport for Jobcorps had a tree growing out of the engine compartment which wasn't in the picture on the sale. Try getting a tree trimmer onto a secure military site sometime from across the country, then rescheduling that transport for an unspecified pick up date but with a drop dead delivery date a week in the future.
Oh and if you miss your targets, your organization gets suspended from further procurement for an unspecified time. You don't agree it would have been nice if it was still in socal, that's OK. |
