EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Android Torque Pro settings (https://ecomodder.com/forum/showthread.php/android-torque-pro-settings-29837.html)
mcbota 08-26-2014 01:04 PM
I had just bought an OBD II interface and I have installed Torque Pro on my smartphone. Having parameters like:engine load, boost, RPM, speed, throttle, voltage, intake air pressure, etc, I am not surewhich one fo these I have to display and follow for the best fuel consumption? Which are the values of these to keep inside it, for the best consumption perfomance, considering an Audi diesel car? Thanks!
Fat Charlie 08-26-2014 01:31 PM
I always had throttle % and load showing. My drive by wire throttle was sensitive at low throttle.
dirtydave 08-26-2014 02:21 PM
I use the instant MPG, trip MPG, TPS and load %.
Or just the bar graph with instant.
Or the shift light plugin to remind you to shift at 2K RPMS.
You just need to take some time with it and see what works for you there are so many options and many are useless to efficient driving.
